what kind of axles do you have?
    beat to shit Dana 30 (with good brakes and bearings) and 29 spline Chrysler 8.25" Rocking 3.55's open/open now for 5 years, currently running 33's.... I've only ever broken the ear of one dana 30 shaft... and that was with 31'....and in mud. So take that as you will, most of you can attest to my driving style.
      with a 29 spline and dana 30 with the bigger 760 u joints you can be locked no problem front and rear on 33s. but im sure since you are just doing light/medium wheeling you will be fine with just a rear locker. the stock 297 u joints in your 99 will be fine up to 35 inch tires if not locked.
        waggy 44s. rears a bolt in to an xj just need to weld a shock tab on, front on the other hand is not
          just to elaborate on disss so dumb people dont go bolting wagina 44's in thier jeeps
          the rear axle will just about bolt in
          but your wheels wont fit the axle
            ahh forgot that part yea waggy 44s are six lug
            my lug patterns are hawkish at the moment
              xj 44 rear and lockrite. hp30 front and aussie on 35's with 4.88's. i'm easy on em and they have lasted so far
                bolt in really?? i thought you had to relocate spring perches. but hey maybe i read wrong...and aren't waggy rears slimmer than a xj axle??
                2013 F150 fx4 (Tow Pig/DD)
                • 5.0 with the 3.73 option
                2003 TJ Rubicon
                • 4.0/42rle/np241or
                • 5.13's
                • 33” BFG KO2s
                  61" WMS for the narrow track IIRC up front and 59" rear I believe.
                    i gots a manche 44 with 4.56's and a detroit, up front is a hp 30 that is open for now it has the larger shafts with the 760 u joints in it. ohhh and i run 33's.
                    i plan on upgrading the front to a 44 by the time my somewhat new 33's die in order to 35's.
                      60 rear built to fuck
                      44 front built to fuck
                      5.38 gears
                      nothin but alloys
                      soopa joints
                      truss
                        i'm surprised no one mentioned an 8.8
