Caliper wont open up
  • #31
    agreed. this hurts my brain to think about without seeing it.
    • #32
      alex take pics of the WJ setup so we have a reference
      • #33
        we should go to the parts store and look at WJ rotors side by side to the sport trac ones everyone likes to use. maybe those will solve the issue.
        • #34
          ill be keepin an eye on this in the meantime
          http://naxja.org/forum/showthread.php?t=977419&page=4
          • #35
            hopefully theyre not all at KOH and naxja will bring the win
            • #36
              I may have figured something out. The 4x4 wire used a hub from a 2000/2001 tj. They have several different rotors for whatever reason jeep does stupid things like that. Probably an ABS thing. I remember this cuz Adam Gabel and I needed to measure his rotors since they had a few options of over all height. I think you need hubs from one of those to push the rotor out further.
              • #37
                damnit, i was told an 01 XJ hub was the same deal and i just bought em and installed em...i better not need to buy 2 brand new hubs a week after i bought these
                as far as i could tel lthe rotor needed to move in, i could be wrong
                • #38
                  97 XJ wheel bearing Flange Offset=2.133"
                  2001 XJ wheel bearing Flange Offset=1.905"
                  • #39
                    im beginning to wonder if these are even fuckin 01 wheel bearings...everthing fits exactly the same as my old 97 bearings with these installed
                    • #40
                      measure em. did you get em from that ghey auto zone that gave me the wrong side caliper after double checking?
                      • #41
                        kyle got them from a hookup he had at the dealer and sent em to me
                        • #42
                          check the part number perhaps? That is about a 1/4" different which would probably push the rotor out far enough for the bracket to sit flush.
                          • #43
                            1/4" is the spacing issue i have.
                            these have to be the wrong year hubs.
                            • #44
                              shweet. I win. sumthing fun to do on saturday
                              • #45
                                we'll buy an 01 hub, test it, if it works, get another, if not, return it.
                                gonna be ass raping cost gettin em locally
