mah jeep is shaking apart......
  • mah jeep is shaking apart......
    No, not death wobble hahaha. When I start off from a stop the whole jeep wants to shake apart. Its a 5 speed by the way. It's not all the time, but a lot of the time. Also, my fan is now hitting the fan shroud when the engine is under a good load. (Like taking off from first to third and the engine is torquing the most). Im feeling motor mounts, but it started after I put the long arms in. I checked to make sure everything was tight with the new arms, and it is. and I checked to see if the shifter moves a lot when im on and off the gas, and it seems normal. I havent checked the motor mounts with a prybar or anything yet but I will tomorrow. Passenger side U joint is shot, driver side is on its way out. Dont know if that would cause that but hey you never know. If anyone has had the same problem or similar please help me out.
    you do have rustys motor mounts....
      im saying your tcase is too low causing the fan to hit the radiator shroud and causing vibes.
        it would have to be hella fuggin low to cause issues like that
        but who knows
          this is def a good theory and I have thought of it. sounds too logical
            but who knows
            well his tcase skid wont work cuz the tcase hangs too low.
              or having the t case so low cause the motor mounts to wear prematurely...
                after 10 miles of driving?
                  probably not lol
                    needs more rectangulation
