No, not death wobble hahaha. When I start off from a stop the whole jeep wants to shake apart. Its a 5 speed by the way. It's not all the time, but a lot of the time. Also, my fan is now hitting the fan shroud when the engine is under a good load. (Like taking off from first to third and the engine is torquing the most). Im feeling motor mounts, but it started after I put the long arms in. I checked to make sure everything was tight with the new arms, and it is. and I checked to see if the shifter moves a lot when im on and off the gas, and it seems normal. I havent checked the motor mounts with a prybar or anything yet but I will tomorrow. Passenger side U joint is shot, driver side is on its way out. Dont know if that would cause that but hey you never know. If anyone has had the same problem or similar please help me out.
mah jeep is shaking apart......
you do have rustys motor mounts....P8R
Originally posted by crosbike View Postim saying your tcase is too low causing the fan to hit the radiator shroud and causing vibes.
but who knows
