your opinion....
  • #31
    oh and this is getting moved to tech now
    • #32
      the bold is my insight, the regular type is their website
      NOW HIGHER CLEARANCE AND BETTER TIRE CLEARANCE! We use an exclusive, non-binding, 3 link setupnot a 3 link noobs, they dont even know what they are selling, but it does use one 10mm bolt to keep your axle in place that has a pair of front long arms that will flex more than you thought possiblecool, there is a thing as too much flex, and you can get it with any longarm kit. You WILL NOT bend these long arms as they are made from 5/16" wall DOM tubingThe bushings at the unibody are greasable super-flex joints that pivot to give as much suspension travel as your shocks will allow. We combine that with factory style rubber bushings at the axle for superior road noise and vibration dampeningand axle wrap? and a reason to carry a spare upper control arm bushing?. As always, this kit is 100% bolt on! ZOMG!NO WELDING and only minor drilling is required for installation. No adjustment is necessary in any part except for our unique caster adjustment bracket that allows 7.5° of adjustability; plenty for any lift height from 4.5-8"!! that caster adjustment is freakin goofy
      Why Fixed Length?
      Strength - With 2" x 5/16" wall DOM straight into the bushing tube, there are NO weak points on these control arms.yes beacause people constantly break their threaded joints in rock races and crawling comps and desert races, but i have never seen an iron rock longarm in any of these events The Iron Y is gusseted with 1/4" laser cut steel gusset for additional support. No threaded rod to rust, bend, mangle on rocks, or worse yet wear out and clunk! see last boldness
      Control Arm/Axle Position - We have designed these arms to be the ideal length for your XJ for any lift between 4.5" and 8". Imagine you add our long arm upgrade to your 6" lift kit. Now 6 months later you want to go to 8" of lift. The axle will only be pulled back less than 1/4"!ZOMG JUST LIKE ANY OTHER LONGARM Remember, the arc that our ideal length long arm travels is always the same, meaning your tire will center perfectly in the wheel well on compression no matter what height lift you are running. ZOMG JUST LIKE ANY OTHER LONGARM
      Easiest Install - You can't get it wrong. You don't have to match your control arms or worry about setting the right length because that is done for you.
      SAVES YOU MONEY!!! - It costs us less to build so the savings get passed to you. ZOMG SO EZ!
      Kit Includes:
      1 Passenger side lower control arm.
      1 Iron-Y radius arm I THOUGHT THIS WAS A 3 LINK, NOT RADIUS ARMthat connects to the upper and lower axle mounts.
      3 piece high clearanceLOL, steel subframe assembly with built in optional transfer case drop
      All required hardware.
      Installation instructions.
      i must say they have gotten better, but i wouldnt trust my jeep and my life with a set.
      • #33
        IRO is pretty gay
        OH.
        fair enough. thnkx
        so extay on the IROay.... good catch on the 10mm bolt as the only thing holding axle upright.
        #becauseJoeNitro
        • #34
          well i have to say that was extremly helpful.
          looks like is roughcountry.
          unless someone can show me a site sellin that TNT kit for around 6beans?
          #becauseJoeNitro
          • #35
            or yeh could gear it and enjoy driving it?
            • #36
              make them
              • #37
                why not just save a few bucks and get a nice set of adjustable short arms? with the 600 bucks plus shipping you could get some short arms and maybe a locker or something. you are gonna be like ZOMG I HAVE LONG ARMS but cant go as far cause you will still be open open. I feel for a low budget build there is better stuff to spend your money on. Like lockers, skids, etc etc. Plenty of people in this group run short arms and have no problem stayin up with the long arm guys. just my .02 since you seemed to want to keep it a low budget build.
                • #38
                  x2 here
                  • #39
                    completely agree with this. your jeep will flex fine with short arms and 3 inches of lift. i mean if you think 2 more inches of drop is more important then some lockerz or gears then go for it. but i know the next thing i'm buying for my jeep are lockerz.
                    • #40
                      I don't see anything wrong with my Rusty's long arms, but there is no way I would pay what I did for the kit again. I haven't checked around prices lately, but at the time I could have gotten the Treks kit for about the exact same price.
                      I also was checking out the new Rough Country setup, and it looks pretty good for the price. Lately I have been hearing good things about RC, especially their customer service so I expect this to live up to the hype.
                      With that said, I agree with Andrew. I don't see why the hell you would be looking to spend a shit ton of money on a kit for a rig you have barely started.
                      • #41
                        the rear is already locked. the long arm kit comes with a transfer case skid and i have a gastank tuck.... so....
                        no need to gear. its on 32's and runs just fine with 3.55's even my old jeep on 33's was great with 3.55's so im not at all concerned. not saying it couldent be better regeared but they dont bother me.
                        Originally posted by greenxj513 View Post
                        make them
                        i dont have a welder or other required tools and by the time i pay for all the material and nail down someone with time willing to help me id be worht the cost of just buying the kit.
                        #becauseJoeNitro
                        • #42
                          lockers and gears b4 long arms
                          • #43
                            my girlfriends tj has a RoughCountry 2.5" lift in it. it was installed jan of last year. i was really impressed with its fit and quality as well as how its holding up and its performance offroad.
                            as ive said b4 if i were to go to the longarm i will be upgradeing the surrounding components as well. steering, trackbar ect... other than that what else is there to worry about. the jeep has one locked axle. its sitting on 3" lift. i have extended travel shocks and longer breaklines. gastank tuck. you say barely started but if i add the longarm and steering then lock th front its fucking built and still dident cost more than $2500
                            total rig cost now is $780
                            add long arm, steering, front locker, and trackbar $600 $300 $300 $130
                            and shits done for $2110
                            #becauseJoeNitro
                            • #44
                              it has a locker...... its on 32's even if it were 33's why the fawk gear it. i never had an issue wit 3.55's getting me anyware in the 96. if i were on 35's or bigger you have a point but no need with 32's.
                              #becauseJoeNitro
                              • #45
                                meh
