8.8 or D44
WHAT ABOUT THE LOSS OF HOLDING POWA!?Originally posted by FireFighter32 View PostPersonally I plan to go with the 8.8 in my current build. Spring perches can be had for $32 from Ruff Stuff. The convenience of disk brakes means a lot. It also depends on what you plan on doing and your set up on your Jeep.
ive seen both the internals on an 8.8 and 44, stock, and the 44 is definately more beef in stock, but i feel the 8.8 can be made just as tough with $$$
i chose the 44, non c-clip and better housing sold me, and mine was $150 so im not gonna complaindirty30
i'd go with the 8.8
million of them
right width
right bolt pattern
as strong or stronger than 44
easily weld the tubes to stop spinning
disc brakes
factory 4.10s
while your at the junkyard get a hp30 with 4.10s and you got factory lower gearing front and rear and a pretty strong set up
that or if i wanted a lil wider stance but not full width waggy 44's front and rearLast edited by Arundlemcbrundle; 10-19-2009, 01:08 PM.2 tj's
The 44s he was asking about did not have bolt in capability1996 xj, waggy 44 front 5.13 gears aussie trussed, 3 links, 3.5" coils, spooled 8.8 rear, 38" tsl sx's, tnt front bumper, jesus freaks rear bumper, Olympic top hat roof rack, bunch of dumb shit
if i wanted to run a 60/30 combo.... id sell you my 44 and bolt my 60 up, but that would be completely unnessesary.
8.8's can be found for cheaper than bolt in 44's too, if you find one with discs and 3.55's literally all you have to do is weld on new perches and shock mounts and go to town. i got an 8.8 that same setup for 100 bucks a while back. you could easily do an 8.8 swap for like 200-250, and barely even have it hurt your pocket.No worries, I'm not actually back, I'm just reminiscing about the old days.
same with a 44Originally posted by greenxj513 View Postyou could easily do an 8.8 swap for like 200-250, and barely even have it hurt your pocket.
but when people ask you what rearend you have, would you rather say
"oh a ford 8.8"
"DANA FOFO BITCHES
ill soon be heading out to the junkyard this week and my buddy their believes theres two or three XJ's with D44's, but if their isnt, i might go with the 8.8.
.,=====o00o ______________
//___l__,\____\,___ ____
l_---\____l----[]lllllll[] _
_(o)_)___(o)_)--o-)_)
