Fucked something up
  • Fucked something up
    so today i did some wheelin with some friends, including Zach, and messed something up in my steering. I think. So, the steering wheel has crazy vibes that shakes the entire body between 20 and 45 mph. But the tires are running normal w/o any vibes. I checked everything in the steering and didnt notice anything. nothing loose or noticeable. I checked the steering column and it has alot of play. when i shake it the steering wheel does move as it would when i drive. any ideas??? oh and can some post what a stock drag link looks like? is there a bend at the left end? (looking head on)
    sorry for so many posts in the tech section but doing alot to my heep. Starting to feel like jeepinjosh
    4x4 Station Wagon...
    can ya post a pic?
    sounds like you got some toe in goin on
        looks normal no???
          that looks fine to me
          have a friend, brother, lawn ornament, etc sit in the front seat and jiggle the wheel back and forth while you check out the front end
          make sure there is ZERO play in every component
            already did. the only place theres play is in the steering column
              still sounds like excessive toe in then.
                which is???
                  you may have bent somethign ever so slightly to make your front tires point inward
                  this relation is toe
                  excessive toe in will cause the front tires to want to push into eachother resulting in either increased tire wear, the badness you are experiencing, or both.
                  but when you say vibes
                  like a driveline vibe? or a wobble?
                    like wobble without the wobble
                      the tires do not wobble at all just the steering
                        oh i forgot to mention that at one point today my steering wheel was turned from vertical to horizontal and my wheels didnt move. so i'm thinking the problem is my steering box? any suggestions?
                          yeah buy my a full hydro system and take the box outa my yj
                            Mine did that when the frame broke
                              x2
                              95 xj JY 3" 35" truxus mt's
