U-Joints
  • U-Joints
    Looking to replace my 297's with some 760's.
    Are the alloy USA ones worth the money?
    http://www.4wd.com/productdetails.as...35&partID=3843
    Just wondering. Any input would be appreciated.
    FUCKING GENO
    Im not really sure. I know the Spicers are the best one you can buy over the counter but Im not sure how they compare. They are relatively the same price.
      Petersons did an article a few years back when the 760 u-joint came out. The 5-760x spicer is the same physical dimensions as the old 5-297x u-joint, but it is an upgraded disign that they claimed was 10 times stronger.
      I think unless you are running an aftermarket alloy shaft axleshaft, it is best to stick to an oem replacement U joint. Save the expensive, super strong U joints for the aftermarket alloy shafts.
      1950 Willys Trail Rig
        Ok so basically, a Dana Spicer 760 is going to be fine and dandy?
        FUCKING GENO
          Geno, stop being a bitch and go to D60s like JeepBoneHead after one ujoint break.
            FUCKING GENO
              l o fucking l
                spicer 760................go. those will be just fine
                  WEll I can get the Alloy USA ones for the same price as the Dana Spicers..
                  So...
                  Now what?
                  FUCKING GENO
                    just get hte alloy usa ones.... if theyre the same price
                      So...
                      Now what?
                      I am guessing they are the same spec as the Spicers... They look the same, needle bearings, probably the same alloy steel. Do some research on the manufacturing and materials used, now I am curious.
                      Or just go with the Spicers.
                        Supposedly the Alloy USA ones are a LITTLE stronger than the Dana Spicers.
                        So since I got them for the same price, I orderd those along with Alloy USA Axle seals this morning.
                        http://www.shopwiki.com/detail/?q=Al...g+by+Alloy+USA
                        Didint get them there, but thats a description.
                        FUCKING GENO
