what are all the dana 44's that are desireable for the front of xj's? not neccissarily full width ones too.. like the waggy 44's which years and what models
desireable front 44's
80-92 waggys without the disconnect
early bronco's work as well, the later ones have a weird pumpkin offset and require a re-tube
aslo the bronco is 5x5.5 bolt pattern, but the waggy can also be converted to 5x5.5 (like i have) with ford hubs.
what are you going to run for a rear axle? if you dont have one yet i would gab a set of waggy axles, that can be had (stock) for a few hundo.Last edited by grundlepunch; 04-28-2009, 09:37 AM."when I'm riding my motorcycle,I'm glad to be alive...when I stop riding my motorcycle,I'm glad to be alive"
the key is matching your front and rear lugs.
a (real) front 44 will make you HAVE to go 5x5.5 or 6 lug in the rear
so that means ether,
-getting an 8.8 and putting cromo shafts with a custom lug pattern "5x5.5" and then using EB 44 or getting a waggy and then converting that to 5x5.5
-getting a matching waggy axles
guess the better choice
check out xjeepers build he is currently doing 6 lug waggy diffs under his xj.Originally posted by XJtheXtremeJeep View Postyeah im prlly gonna try to find a matching set of waggy 44's and building them, i heard that the 6 lug waggys are a pain in the ass to do? i could be wrong tho, ive never really looked into doing the waggy axles1996 xj, waggy 44 front 5.13 gears aussie trussed, 3 links, 3.5" coils, spooled 8.8 rear, 38" tsl sx's, tnt front bumper, jesus freaks rear bumper, Olympic top hat roof rack, bunch of dumb shit
