1" impact gun
Lug Nut seized!!
true true... wasn't thinking about the drivers side. Me and Raze (ok Raze and I) took off a crank bolt on a volkswagon today by jamming a bar against the lower a arm and cranking the motor... Don't see why it wouldn't work on a wheelOriginally posted by BeachinXJ View PostThat will tighten them on the drivers side! You want to do it and drive in reverse.
Originally posted by Fast Orangeif you piss all over the floor and get 3 drops in the bowl do you count that as good? granted i'm good for a sprinkle or two on the seat, but you leave all of our feet wet, metaphorically speaking of courseOriginally posted by HitItWithSomeSpeedI find adam sandler strangely attractive, it must be josh's fault. god that kid sucks
because we were too lazy to push it closer to the air compressor. would work on wheels. ill try it on a yj outside and see how it works.Originally posted by ruecifur View Posttrue true... wasn't thinking about the drivers side. Me and Raze (ok Raze and I) took off a crank bolt on a volkswagon today by jamming a bar against the lower a arm and cranking the motor... Don't see why it wouldn't work on a wheel
do it to the rear axle... still need the front for a couple weeksOriginally posted by Fast Orangeif you piss all over the floor and get 3 drops in the bowl do you count that as good? granted i'm good for a sprinkle or two on the seat, but you leave all of our feet wet, metaphorically speaking of courseOriginally posted by HitItWithSomeSpeedI find adam sandler strangely attractive, it must be josh's fault. god that kid sucks
What? Yes these Little fucking lug nuts and I can't get them off HAHA! The power is not the problem it is getting something to lock on the nut I hammered a socket two sizes to small on one today and still it spun but didn't brake. I'm going to just pull the axle shaft and get at them from the inside!Originally posted by XJLI View Postyou should weld your front axle
Try heat and a breaker bar......if not....pray.
Be thankful it's not a torqued oil pan drain plug.....fucktards at jiffy lube did that to my ex gf's car 5 years ago.....and what a fucking job to try to fix it
1998 XJ.....Finally.
...And I'm a Mac
put a pipe on a breaker bar1996 xj, waggy 44 front 5.13 gears aussie trussed, 3 links, 3.5" coils, spooled 8.8 rear, 38" tsl sx's, tnt front bumper, jesus freaks rear bumper, Olympic top hat roof rack, bunch of dumb shit
6 ft legnth of DOM i have works wonders..........Originally posted by raze1287 View Postput a pipe on a breaker barNo worries, I'm not actually back, I'm just reminiscing about the old days.
unless it breaks and you go flying 10 feet. done that before.Originally posted by greenxj513 View Post6 ft legnth of DOM i have works wonders..........
i would soak with PB, then with and impact gun try to loosen them and if still no luck try to tighten them slightly just bump them a lil tighter then crank on them in reberse there is probably a lot of metal bound in the threads.
Heat and ATF are viable options as well, an impact gun will give you more torque than you could prob get from the breaker barhttps://sisoffroad.com/forums/core/i...smilies/us.gif 2017 Chevy Silverado 1500 https://sisoffroad.com/forums/core/i...smilies/us.gif
https://sisoffroad.com/forums/core/i...smilies/us.gif 2000 Jeep Cherokee Sport https://sisoffroad.com/forums/core/i...smilies/us.gif
94,95,97 ZJ~SOLD 97,97 TJ~SOLD 00' F350~SOLD
an impact gun will not usually give you more torque than a long breaker bar. most impact guns are 600 to 700 ft lbs of torque where a 4 ft breaker bar with only 175lbs of force will produce 700 ft lbs of force. i have a 1200 ft lb impact gun and i still find myself getting out the pipe to brake stuff loose.Originally posted by Grandzjtsi View Posti would soak with PB, then with and impact gun try to loosen them and if still no luck try to tighten them slightly just bump them a lil tighter then crank on them in reberse there is probably a lot of metal bound in the threads.
Heat and ATF are viable options as well, an impact gun will give you more torque than you could prob get from the breaker bar1996 xj, waggy 44 front 5.13 gears aussie trussed, 3 links, 3.5" coils, spooled 8.8 rear, 38" tsl sx's, tnt front bumper, jesus freaks rear bumper, Olympic top hat roof rack, bunch of dumb shit
I get you on the leverage, just not many people are gonna hang off of the end of a 4ft piece of pipe (jack handle works great I've done it myself) to get that kind of force on the lug nut.....I agree though breaker bars and tube is the best thing in a pinch
We've got one of these down in our shop older model but same design
http://buy1.snapon.com/catalog/item....re&dir=catalogLast edited by Grandzjtsi; 04-28-2009, 10:12 PM.https://sisoffroad.com/forums/core/i...smilies/us.gif 2017 Chevy Silverado 1500 https://sisoffroad.com/forums/core/i...smilies/us.gif
you can buy 1/2" guns with that much torque now.
[ame]http://www.amazon.com/Pro-Grade-1000-FT-LB-Impact-Wrench/dp/B000HB2ZMI[/ame]Originally posted by Fast Orangeif you piss all over the floor and get 3 drops in the bowl do you count that as good? granted i'm good for a sprinkle or two on the seat, but you leave all of our feet wet, metaphorically speaking of courseOriginally posted by HitItWithSomeSpeedI find adam sandler strangely attractive, it must be josh's fault. god that kid sucks
qft. my snapon 1/2" gun creates 1200ft/lbs of torque and i have broken stuff loose with a 2 foot breaker bar that the gun couldnt.Originally posted by ruecifur View Postyou can buy 1/2" guns with that much torque now.
http://www.amazon.com/Pro-Grade-1000.../dp/B000HB2ZMI1996 xj, waggy 44 front 5.13 gears aussie trussed, 3 links, 3.5" coils, spooled 8.8 rear, 38" tsl sx's, tnt front bumper, jesus freaks rear bumper, Olympic top hat roof rack, bunch of dumb shit
