Lug Nut seized!!
  • Lug Nut seized!!
    I went to take the rear wheels of my New four door XJ so I can start doing the lift and some other stuff today and found out that all five nuts on the driver side are Seized and one on the pass. side. The pass. side one I just used a air hammer and beat it till it was gone and I will replace the lug but the others are just to many to beat off. I mean I beat a socket two sizes small on one and put a 24" breaker bar with another 24" bar on it and it just stripped it around and I put a bend in my new breaker bar!Then my BIG Impact beat it till the socket was to hot to touch and nothing but stripping! I do not won't to spend a week Drilling them all out any help? Used PB blaster I used everything but heating them up and going to sears and looking for a 19mm stripped nut extractor or whatever they are What do you guys recommend? Were can I get a nut splitter that will fit into the deeper wheels?
    keep PB blasting for a couple days and use heat
      yea id say heat them up and crank on them with the impact. they are stripped on there you will have to replace the studs and lug nuts anyway
        heat em up, then try to take them off. Use a BIG cheater bar.
          jam the breaker bar against the ground and drive forward
              heat. it's the best wrench out there.
                Originally posted by Joker2669 View Post
                what... that will work... probably... um, maybe
                  If your lug nuts are seized on I can only imagine how stubborn the front leaf spring bolts are going to be.
                    some fucktard in the past probably sat there with an impact for a couple minutes "OMG DONT WANT WHEELS FALL OFF"
                      i herd heating them up then cooling rapidly with pb blaster does wonders any trick is tranny fluid if you can soak them in tranny fluid that should free them up
                        I am going to try that one day on a vehicle that isnt mine.
                          you are bigbadxj and you cant get a little lug nut off?
                            you should weld your front axle
                              That will tighten them on the drivers side! You want to do it and drive in reverse.
                              -Kyle
                              2000 XJ - it still almost looks like one.
                              http://www.sira4x4.net
