When welding my lower control arm mounts on my 44, i measured the stock width on my d30, and compared that the the 44. The short side tube is too short so i figured the lowers CA's could angle outwards slightly and it would be fine (long story made short).
Well i just tried bolting up the axle, and the lowers mouted fine. But when i try to bolt up the uppers, they don't line up right. Like the lowers are too far apart, and they put the uppers at too far of an inward angle. Now i could probably try to bolt one side in at a time, but i'm not sure if that would put a lot of pressure on the bushings, and wear them out extremely fast, or cause way too much binding.
On the center cast section, on the short side tube there is about 3/4-1" that looks like you could technically cut off. I'm thinking i should have done that and moved both mounts in?
Now i'm looking at all this shit in the dark with poor lighting. I'll have to take a closer look tommorow morning.
