Doorless quick disco's
  • Doorless quick disco's
    I've been all over and cant find a big enough size. Please correct me if im wrong but i need 5/16 x 4in' pull pins, correct? And were did you go to get yours??
    4x4 Station Wagon...
    i used the stock pins...? just left them in place on the driver side and cut them down a bit, flipped em over on the pass side and trimmed aswell.
    #becauseJoeNitro
      he has a 98 XJ.
        i use the stock ones
          I used a bolt that I grinded the threads off of to pass through the hinge, left the bottom few rows on to tighten a bolt onto. Worked fine the whole time I DD'd the thing.
          -Kyle
          2000 XJ - it still almost looks like one.
          http://www.sira4x4.net
            I did the same but didnt even bother using a bolt on the bottom. shit stays in there just fine. heres a pic, and i think its 5/16
            bottom:
            top:
              heres what i got they are a bit shorter now i found that the full pin for the bottom was a pita to get on and off... the top and bottom both look the same, i also put in brass bushings in there so they are still tight as brand new
