What are your recommendations as far as u-joints for axle shafts?
u-joint selection
how many do you need. I have one brand new in the box in the garage. 20$Dan.
im installing an aussie and noticed that the joints are shyt on both sides. someone localy has some shafts and one has a good spicer joint in it. i need one for the driver side. and dan that would be nice but your a good distance away from me. thanks for the offer tho. what do you guys think of moog joints?98 xj, 4.0, AW4, 231 AA SYE, 4.5"RE/RC, CA drop brackets, 33s, and some other stuff
With a locker, nothing but spicer.Dan.
Not as good as spicer. Putting a spicer in is cheaper than breaking a cheap joint and taking out the axle. I definitely found spicers hold up way better. Look at Reid, both his axles at rausch had cheap joints right? They both brokeOriginally posted by Harry View PostSpicer probably is the best, but Moog is no good at all?Dan.
One was cheap, one was Spicer.Originally posted by ct67_72 View PostNot as good as spicer. Putting a spicer in is cheaper than breaking a cheap joint and taking out the axle. I definitely found spicers hold up way better. Look at Reid, both his axles at rausch had cheap joints right? They both broke97 XJ.
Dana 30's used 2 different series u joints. A 260x and a 297x that is larger. What year are your shafts from?Dan.
