u-joint selection
  • u-joint selection
    What are your recommendations as far as u-joints for axle shafts?
    spicer
      somewhere local to buy?
        Locally?.... no clue
        can wait 3 days?
        ECGS U-joints
          how many do you need. I have one brand new in the box in the garage. 20$
            Make sure it's the right size
              im installing an aussie and noticed that the joints are shyt on both sides. someone localy has some shafts and one has a good spicer joint in it. i need one for the driver side. and dan that would be nice but your a good distance away from me. thanks for the offer tho. what do you guys think of moog joints?
                With a locker, nothing but spicer.
                  Spicer probably is the best, but Moog is no good at all?
                  97 XJ.
                    Not as good as spicer. Putting a spicer in is cheaper than breaking a cheap joint and taking out the axle. I definitely found spicers hold up way better. Look at Reid, both his axles at rausch had cheap joints right? They both broke
                      One was cheap, one was Spicer.
                      97 XJ.
                        Spicer it is then! are there different joints? strength wise? any site recomendations?
                          Dana 30's used 2 different series u joints. A 260x and a 297x that is larger. What year are your shafts from?
                            If you have 297 you can go with spicer 760's which I believe has a slightly larger trunion than the 297's. oh and camarota truck parts in Northhaven sells them as well. I got my cheap from there but we also have an account with them.
                              its a 98 with stock shafts. and i have a pair from an 01
