When i swapped rear discs into my XJ, i grabbed the prop valve from the junkyard but never swapped it in. My brakes are starting to go the floor again and i think it's a combination of bad brake pads and an inadequate prop valve.
I'm going to put in new brake pads tonight and re-bleed the system so i figured i should swap it in now.
I have the ZJ prop valve sitting in my garage, but i think i need to do something to it to make it work. How would i swap a ZJ prop valve into an XJ?
Dummied down instructions would be a plus.
