Aussie locker tech...
    Originally posted by Burton58 View Post
    did you check the clearances and try to fix it first?
    I didnt. No time or means or drive to deal with wrenching/ troubleshooting in the cold. Just wanna drive it
      Driver side c clip doesn't come out until the other half of the locker is removed from the axle.
      Did you try tilting the center plate a removing it that way?
        This is exactly what i thought/read. Fuckin a. Tried everything.
          Hurmmmmmmmmmm....
          Even tried rotating the carrier and see if it came out the other side? I can't imagine not being able to get that out...that's weird...
            Yeah. Both alex and i were tryin.
              Ydtshcjvivtzrsyfihofwwt,tugucydjc
                Sawzall Solvzall.
                  If all the pins and springs are removed then there should be enough room so that the teeth clear. How much room do you have/how much room till the teeth will clear? Do both side gears look equally inserted into their side of the case?
                    Hammer didn't work either, I suggested 5.56 but someone shot that plan down.
                    YJ on 37s, coilovers, etc
                    MaxRev MotorMedia
                    Jonasson Motorsports
                      at this point just remove the shafts and take the whole carrier/ring gear out.
                      edit: you couldn't get the other c-clip out... hmmmm
                        Reading comprehension is pretty rough over here isn't it? /s/
                        MaxRev MotorMedia
                          the memory lacks in my old age
                            My brain goes fuzzy being in Connecticut.
                            MaxRev MotorMedia
                              it's the fumes
                                Did you spin the center pieces in the carrier to line up the flats?
                                The pieces are larger than the carrier opening and have flat spots top and bottom to fit through.
                                Sometimes the opening is not even also, and one side is more open than the other.
