Originally posted by Bigbike
Today i cried and heard thunder under my Jeep
I can handle the swap thanks for the offer i might have joe nitro come help if he can i just need to know what to get ...axles officially confuse the shit out of me95 Yj 4.0, Flowmaster 40 series exhaust, Blue Hids and Yellow Fog Lights, K&N air filter, 2" Boomarang shackles, and sway bar and track bar removal.
Long tube, gears inside, gears turn shaft, shaft turns wheel, your gears fail.....better?Originally posted by 95jeepYJ View PostI can handle the swap thanks for the offer i might have joe nitro come help if he can i just need to know what to get ...axles officially confuse the shit out of meI don't always drink orange juice, but when I do, I prefer to chew it. #madpulp
If its like an XJ
4.0 w/ auto-3.55 gears
4.0 w/manual- 3.07
2.5 w/any trans- 4.10
These are in most circumstances, and I am guessing YJs are similar to XJs gearing wise.-Caleb
Idk what to do.... i need a new axle so i can work i do delivery in my jeep with no jeep no job no job no parts no parts no fun..... so yeah idk...Originally posted by Bigbike View PostIf its like an XJ
4.0 w/manual- 3.07
These are in most circumstances, and I am guessing YJs are similar to XJs gearing wise.95 Yj 4.0, Flowmaster 40 series exhaust, Blue Hids and Yellow Fog Lights, K&N air filter, 2" Boomarang shackles, and sway bar and track bar removal.
http://hudsonvalley.craigslist.org/pts/1092146808.htmlOriginally posted by Bigbike View PostFind a yj with a 4.0 and a 5 speed(the same drivetrain as yours) then swap axles.95 Yj 4.0, Flowmaster 40 series exhaust, Blue Hids and Yellow Fog Lights, K&N air filter, 2" Boomarang shackles, and sway bar and track bar removal.
d35 with 4:10 gears off a wranglerOriginally posted by Bigbike View PostFind a yj with a 4.0 and a 5 speed(the same drivetrain as yours) then swap axles.95 Yj 4.0, Flowmaster 40 series exhaust, Blue Hids and Yellow Fog Lights, K&N air filter, 2" Boomarang shackles, and sway bar and track bar removal.
The Dana 35 in Wranglers equipped with 4-cylinder engines had a 4.11 gear ratio (37 teeth on the ring; 9 teeth on the pinion). The Dana 35 in Wranglers equipped with 6-cylinder engines had a 3.08 gear ratio (37 teeth on the ring; 12 teeth on the pinion).95 Yj 4.0, Flowmaster 40 series exhaust, Blue Hids and Yellow Fog Lights, K&N air filter, 2" Boomarang shackles, and sway bar and track bar removal.
i'm gonna shed light on this for you. you have a 6 cyl yj thats a manual transmission and isn't a sahara. its pretty much guaranteed that you have a 3.07 gear ratio. direct swap in for you is to find another d35 outta a yj with the same trans and motor setup (aka a d35 with 3.07 gearing). anything else isn't gonna be a direct swap. if u wanna talk about upgrades. easiest and cheapest way to go is to find a yj with a 4cyl manual transmission. those jeeps came with the same axles and set up the same way you yj is but they came with 4.10 gearing. that will make your jeep have alot more pick up low end but loose top end speed. if you plan on lifting you jeep in the near future (i think u are) try to find these axles. with the bigger tires this gearing will work great. just remember you need to do the front axle as well because the gearing has to be the same front and rear. right now your gearing is 3.07 front and rear. goal is to go 4.10 front and rear . . . any other ?'s just ask2 tj's
the different ones confuse me and different gears .....
