Today i cried and heard thunder under my Jeep
  • #61
    Originally posted by Bigbike View Post
    If you cant handle the swap Ill take it off your hands.
    I can handle the swap thanks for the offer i might have joe nitro come help if he can i just need to know what to get ...axles officially confuse the shit out of me
    • #62
      Long tube, gears inside, gears turn shaft, shaft turns wheel, your gears fail.....better?
      • #63
        I understand how the work the different ones confuse me and different gears .....
        • #64
          i was going to go into detail on better axles but im going to bed
          good luck with the swap
          • #65
            If its like an XJ
            4.0 w/ auto-3.55 gears
            4.0 w/manual- 3.07
            2.5 w/any trans- 4.10
            These are in most circumstances, and I am guessing YJs are similar to XJs gearing wise.
            • #66
              If its like an XJ
              4.0 w/manual- 3.07
              Idk what to do.... i need a new axle so i can work i do delivery in my jeep with no jeep no job no job no parts no parts no fun..... so yeah idk...
              • #67
                Find a yj with a 4.0 and a 5 speed(the same drivetrain as yours) then swap axles.
                • #68
                  http://hudsonvalley.craigslist.org/pts/1092146808.html
                  • #69
                    d35 with 4:10 gears off a wrangler
                    • #70
                      i wouldnt rely on xj database for his yj for gearing
                      • #71
                        ^^^^ good find, buy them now
                        • #72
                          The Dana 35 in Wranglers equipped with 4-cylinder engines had a 4.11 gear ratio (37 teeth on the ring; 9 teeth on the pinion). The Dana 35 in Wranglers equipped with 6-cylinder engines had a 3.08 gear ratio (37 teeth on the ring; 12 teeth on the pinion).
                          • #73
                            3.08 or 4.10 are better
                            • #74
                              dana 35 FTL
                              • #75
                                i'm gonna shed light on this for you. you have a 6 cyl yj thats a manual transmission and isn't a sahara. its pretty much guaranteed that you have a 3.07 gear ratio. direct swap in for you is to find another d35 outta a yj with the same trans and motor setup (aka a d35 with 3.07 gearing). anything else isn't gonna be a direct swap. if u wanna talk about upgrades. easiest and cheapest way to go is to find a yj with a 4cyl manual transmission. those jeeps came with the same axles and set up the same way you yj is but they came with 4.10 gearing. that will make your jeep have alot more pick up low end but loose top end speed. if you plan on lifting you jeep in the near future (i think u are) try to find these axles. with the bigger tires this gearing will work great. just remember you need to do the front axle as well because the gearing has to be the same front and rear. right now your gearing is 3.07 front and rear. goal is to go 4.10 front and rear . . . any other ?'s just ask
