Steering/Swaying question
Both uppers are in, caster is set at -7 from the top of the c, It rides smother but didn't effect the wondering on the road. Gonna put the stock pitman arm back on sometime monday.
Im just trying to figure this out, there is a such thing as to much drop on a pitman arm correct? What would this cause as a result? How come some kits for 4.5 come with the drop if im a little taller than that and am better off with the stock one?God made the world in seven days, on the 7th day, he made the Le Car
Originally posted by justtorchit View Postno, the top of your inner c, where the upper ball joint goes(can also measure on the balljoint) should be tilted back 6 degrees... fuck whatever angle the pinion is at...Originally posted by JeepBabiiXJ View Postbecause you set too much caster!!!!!
-4.5 degrees from the bottom of the inner c
Which one?God made the world in seven days, on the 7th day, he made the Le Car
IDK, the angle i'm telling you and from where is how we do it at the shop
either should be close enough though i guessNo worries, I'm not actually back, I'm just reminiscing about the old days.
i dont think that 7° is to much.... if anything it would want to snap back to center faster. i run 6° when i build shit and have never had an issue. so im guessing 7° would be no diffrent.
give it a shot and go to 4°, only takes a few minutes.
btw, did you check your toe? use a couple strait edges and some soda cans if you dont have toe plates. (ill explain if you dont already have a way to check the toe)Originally posted by Ktmracer419some people choose video games
Originally posted by justtorchit View Posti dont think that 7° is to much.... if anything it would want to snap back to center faster. i run 6° when i build shit and have never had an issue. so im guessing 7° would be no diffrent.
btw, did you check your toe? use a couple strait edges and some soda cans if you dont have toe plates. (ill explain if you dont already have a way to check the toe)I don't always drink orange juice, but when I do, I prefer to chew it. #madpulp
