Relative axle strengths/ Tech Thread
    I think I just broke a 30 spline dana 60 outer miller locked axle running beadlocked 39s more to come
    1950 Willys Trail Rig
      Originally posted by Arundlemcbrundle View Post
      did not know yj 30's went as deep as 5.89 . . . hrmmmmmmm
      4.88, YJs are HP
        plz elaborate....
          special note for low pinion dana30's. don't put money into them. a high pinion dana30 from an xj is a direct swap and you gain ring and pinion strength as well as a driveshaft that wont spin in the rocks.
          any certain year xj?
            Originally posted by kev711
            "special note for low pinion dana30's. don't put money into them. a high pinion dana30 from an xj is a direct swap and you gain ring and pinion strength as well as a driveshaft that wont spin in the rocks."
            You will most likely want anything 96+, which was the year they switched to the 297 ujoints (stronger). Also, very early models had vaccum disconnect.
              84-99 Xjs had HP D30s but your best years to get are 92-99, or 95+ due to bigger ujoints. 84-94 used a smaller ujoint, but you could always put your TJs shafts in to get the bigger ones.
                Originally posted by justtorchit View Post
                plz elaborate....
                Going up these rock steps
                Turns out I just broke the hub, Milemarker Supreme Stainless Sailor Specials the rep said if I ever have a problem to send them back, hopefully they will warranty them I have only wheeled them about 10 times. I'll put a pic up later.
                  The weak link. Yes they were locked in all the way.
