Brake line ID. And also local source
    good to know
    i was curious why YJ front lines were suggested vs an obvious rear application
    on my zj disks i used those chevy lines that were supposed to be for the front. as justin said, if the banjo bolt fits you're good to go
      FWIW for the sake of tech, i ended up using a stock XJ front line...worked like a charm
        good to know
        I have YJ lines on mine, they are good on an xj up to around 3.5" lift so they figured you had the same dia lines and disks in the rear so why wouldn't fronts work? only cost about 15 or 25 for the set at napa
        1992 xj Briarwood
        Welded front and rear
        13' LED roof lights
        Disco ball
        Truck nuts
        Spinners
