Brake line ID. And also local source
  • Brake line ID. And also local source
    Found one of my rear brake caliper lines rubbed through on a bolt to a pinhole.
    I need to replace this by Wednesday of next week, sooner the better
    I have the Teraflex rear disc conversion...the caliper lines look like below.
    I find it hard to believe this is a special "Teraflex" part. What are these things out of, anyone know? I have heard conflicting reports that the tera kit uses Explorer parts. Lookin to source locally for speediness. Plus 70 bucks for 2 brakelines, brackets, bolts, and so on when I only have a pinhole in one of mine is kind of unreasonable. I dont know much about interchangeability for rear disk brake lines like I do fronts. Would ZJs work? Explorer 8.8? Similar?
    http://www.quadratec.com/products/12700_405.htm
    hey will, teraflex use's 95-01 ford explorer 8.8 calipers/rotors/pads etc. so if you got a hose for one of them, i dont see why it shouldnt work. drive to parts store, bring tools to replace in parking lot so you can match it up
      good to know theyre 8.8 calipers, i'd say that narrows the search quite a bit, thanks dude!
        Ask erich what his rear lines look.like, those look similar if I remember correctly
          That looks like the hose I have from the frame down to the axle, which is RE. I have hard lines coming from the distribution block that go into these on each side...
          http://www.autozone.com/autozone/par...9_168069_5913_
            Sounds like a trip to autismzone tomorrow
            thanks guys, life savers
              I just looked on napaprolink. I dont think those are explorer lines. Im looking some more though
                crown vic is the closest I see. 99 ish.
                one more
                Part: UP 609640
                Product Line: Brake and Clutch Hoses and Cables
                List Price
                Your Cost
                Unit
                27.27
                21.82
                Each
                Qty Available: 0.00 UP|609640|UBK609640_0299778158|0.00|Brake Hose - Left Rear
                Qty
                Features & Benefits
                Direct Replacement Hydraulic Brake Hose Designed To Fit Specific Vehicle Applications & Positions; Hoses Constructed Of EPDM Rubber & PVA Braid, Offering High Dynamic Strength, Chemical & Thermal Resistance; Brake Hoses w/ Banjo End Fittings Are Packaged w/ New Copper Washers To Assure Proper Sealing; Brake Hoses Tested Up To 4,000 psi
                Attributes
                Brake Hose End Type : Banjo & Female - 3/8"-24
                Brake Hose Length : 11.625"
                Caution Statement : Do Not Use w/ Petroleum-Based Fluids - Designed Only For Use w/ DOT Approved Silicone Or Glycol-Based Brake Fluids
                Warranty
                Warranty information is unavailable.
                Material Safety Data Sheet (MSDS)
                There is no MSDS for this item
                Application Information: 2000 Ford Truck F150 1/2 Ton - Pickup
                Brake System Types : 4 Wheel Disc Brakes
                Comments: To 8,500 lb. GVW
                Per Car Qty: 1
                  I would bring your banjo bolt with you I've had to trill the banjo out before.
                  Speedway motors has kits too but I don't know how fast you will get them.
                  Most are Inverted Flare 3/16 line 3/8 24 thread.
                  If it has a cone bottom it is IF if flat it is a bubble flare
                    Can someone explain to me why that fucking kit Will linked is $75?
                      GREED
                      -Tim
                        Interesting, I mailed teraflex right before I made this thread asking them what they thought I could use as a local source for a line
                        They got back to me and said "Try using a 87-91 Jeep YJ wrangler front hose."
                        Interesting.
                          Interesting.
                          DOESNT EVEN LOOK CLOSE. has a long metal lead tot he caliper.
                            XJ front hoses are shorter than YJ hoses
                            Why wouldn't Explorer rear hoses work?
                            Basically anything will work if it is the right flare banjo ID and length just find a nice part store.
                              good to know
                              i was curious why YJ front lines were suggested vs an obvious rear application
