so when i bought the jeep it had no rear shocks the shock mounts on the body are broke off and u can see were someone tried to weld them but didnt do a good job idk what to do to fix this so they are strong
shock mounts
so youre talking about where they bolt in to the top right? like under your cargo area? if you would be able to get some pics wed be able to help you more. all that is there for factory shock mounts is two holes and like a bump for the top of the shock to rest in. if the bolts are broken then you can cut/drill them out and replace them.
check this out, see if it helps.
http://www.rocklizardfabrications.co...ock_mounts.htm
also, if you took out your rear swaybar you can make cheapo bar pin eliminators out of the endlinks like mine. 3rd pic down http://sisoffroad.com/forums/showthread.php?t=11271
here is the link on how to do that. http://www.lunghd.com/Tech_Articles/.../Rear_BPEs.htm
hope this helps, if not, post some pics and ill try to help
Last edited by Trailer Ray; 03-01-2011, 10:39 AM.Watch your backhoe, I'm the John Deere man.
no not at all. i just used some self tappers to mount the bracket, then the cb just sits in that. the hardest part is figuring out the best way to hide the wires. i threw mine up and theyre starting to come down a little bit and the tape is falling off.Watch your backhoe, I'm the John Deere man.
