rear end locking up
  • rear end locking up
    so i threw an rc 4 inch xflex lift on my zj. now my rear end locks up as im going down the road. also it clunks hard and loud. any ideas whats going on?
    do u have a slip yoke eliminator? how are your driveshaft u-joints?
    i live in groton to
    95 xj JY 3" 35" truxus mt's
      no sye and my ujoints look good. nice to hear from some more local people. im at my wits end with this lift man.
        drive shaft may be binding up.
          This. Can't think of anything else... check your drive shaft angles.
          Eric
            i live in groton to
            I live not to far away in Norwich, work right down 95 in old saybrook
              yeah, throw your t-can in neutral and go underneath your rig and peep whats going on under there
                oddly enough i put a transfer case drop and everything stopped clunking. im guessing my pinion angles were off just enough to make it act up. pretty pumped. took it down to town fair tire and got an alignment after i cut some stuff out so my wheels wouldnt rub at steering wheel lock.
                  What was probably happening was that the driveshaft angles were changing due to torque while on the gas, causing binding. I have a little bit of this happening at the moment. Everything looks good when you hop under the rig, even though they aren't. Glad to hear it's fixed tho.
                    i would still do a sye though totally worth it dude.
                    Dizz dizz go sleep sleep
                    Driver 4677 FSM vehicle
