Yesterday i was driving home from danbury and i decided to stop and grab something to eat, then take back roads home. Im sitting at bk and i look at my temp gauge, and it's all the way at 260, pulled into a spot, look and everything seems to be in order. Get on rt 7, start driving and the temp goes down to around ~230, does the same thing at a stop light (i had the heat cranked all the way home). Im thinking that the electric fan isn't turning on and when not moving there is no air going through the radiator.
What should i check first, if i were to hard wire it to the battery, would it be on all the time or just when the jeep is running? and what are the pros/cons to using a switch to manually turn it on/off?
