about 250, im not loosing coolant unless it pukes out of the overflow bottle so i doubt it's a head gasket. And it cools down the faster i drive so im gonna wash out my radiator to make sure nothing is in there
Temp Problem
On a side note, when im accelerating, sometimes right before it shifts into the next gear, it'll goose itself, almost as if im getting on and off the gas quickly, not sure if this has anything to do with it.God made the world in seven days, on the 7th day, he made the Le Car
well to answer your previous question, there really is no downside to wiring your electric fan to a switch. Just remember that it is on a switch and you should shut it off when you shut the jeep off. If you just wire it straight to the battery it will be on all the time, as a battery doesn't stop doing its thang when the motor is off.1993 XJ sport 3.5" rustys 33" MTZ's armored.
is it low on coolant from overheating?Originally posted by LittleD View PostNow the jeep also doesn't have heat89XJ Pioneer Edition 3.5" 33s ravines 4:10s 8.8- parted but not forgotten
95XJ tons 3 link 36s 5:38s
97 F-250HD 7.3 Turbo Diesel
"Shut up and Wheel"
So i got home and started working on it, when i worked on the heater core earlier last month, all i did was swap lines and left it like that, so i swapped them back, and bled the system. Then i washed out the front of the radiator which led to mass amounts of dirt/mud/sand to pour out, and now it runs like a champ again.God made the world in seven days, on the 7th day, he made the Le Car
Originally posted by LittleD View PostSo i got home and started working on it, when i worked on the heater core earlier last month, all i did was swap lines and left it like that, so i swapped them back, and bled the system. Then i washed out the front of the radiator which led to mass amounts of dirt/mud/sand to pour out, and now it runs like a champ again.
yea air flow through radiator will cause over heating
glad its fixedup to 40% off parts from advance auto parts, buy online and pick up at store for free-click here!
