Heard this might be a bad clock spring. Can anyone confirm this? Ive read that the horn stops working and the airbag light stays on. In my case, the horn wont stop honking and the airbag light goes on and off occasionally.
Horn just went off randomly and wont stop....airbag light also goes on and off
either bad clockspring or insulator for horn inside steering wheel is loose/worn through causing contact with other metal parts
Same thing happened in my Camaro. Unplugged the horn and sold it
. Same thing is also happening in my truck I am planning on simply disconnecting the horn and installing 130db train horns. That is always an option but my guess is that you have a loose wire somewhere that is grounding itself and completing the circuit for the horn forward of the horn button. Just my 2 cents it sounds like your airbag light and horn are not 100% related.
Eric
1999 Jeep CHEROKEE Recall ID from NHTSA: 00V105000
Auto Recall Date: 04/11/2000
Vehicle Component: AIR BAGS:FRONTAL:SENSOR/CONTROL MODULE
Estimated Vehicles Affected: 395000
1999 JEEP CHEROKEE Defect Summary:
VEHICLE DESCRIPTION: SPORT UTILITY VEHICLES. WATER AND/OR ROAD SALT IN THE PROXIMITY OF THE AIR BAG CONTROL MODULE COULD LEAD TO CORROSION.
Defect Consequence:
SUCH CORROSION CAN LEAD TO ILLUMINATION OF THE AIR BAG WARNING LIGHT OR COULD ALLOW INADVERTENT DEPLOYMENT OF THE AIR BAGS.
Remedy:
DEALERS WILL REPLACE THE AIR BAG CONTROL MODULE AND LOCATE THE NEW MODULE ON THE TOP OF THE TRANSMISSION TUNNEL.
Notes: DAIMLERCHRYSLER CORPORATION, 860
http://www.autobuyguide.com/1999/12-...lls/index.html
Could be your airbag light issue...I just called the dealer and they ran the last 8 of my vin. At some point in it's existance it was fixed somewhere in the country. Any dealer can run it and see if yours was recalled or what recalls yours had.
I googled "1999 jeep cherokee recall" and that site came up.
What year is yours?
