lsd dana 35
    Originally posted by Sphinx6211 View Post
    SO.... let me see... I have a FREE lsd dana 35 and have an awesome neighbor that is going to swap it into mine for FREE, and you say dont do it.
    All its going to cost me is gasket sealer and some oil. I deffinately wheel my jeep probably more than anyone on this site, and my dana 35 in my jeep has no problems and neither did my last jeep. So far so good..
    If you wheel a Dirt Road every day and call it wheeling, then yes, you wheel more that me.
    Until then, unless you are wheeling Crawl Daddy every other weekend, you aren't wheeling.
      is this serious? I want to believe youre joking, no one would willingly try and sound like that much of an ass hat
        LOLWUT?
          bold statement right derr...
          1981 CJ8 - old & dumb
          2001 TJ Sport - DD
            Must bow to the master of D35 Wheeling!
            95XJ tons 3 link 36s 5:38s
            97 F-250HD 7.3 Turbo Diesel
            "Shut up and Wheel"
              If you are only swapping internals:
              I wouldn't just bolt it in and go, not all housings are the same (hence why every ring and pinion needs to be set up in that particular axle, it comes down to thousandths of a inch but in gears that can matter), swap the carrier from one with the ring gear, shims and bearings to the other as well as the pinion. but don't just call it quits there, and throw the cover on it. I'd get some marking paint and check the pattern to make sure it is acceptable, if that housing is different by 5 to 10 thousandths of inch its possible the gears won't be set-up ideally.
              That and i love newbs that "wheel" so much more than a bunch of people he doesn't even know.
              Comments like that are unnessesary, esp if you come in here wanting tech advice for a d35. Normally i'd be a total douche and tell you to go play on jeepforum.
                I wouldn't just bolt it in and go, not all housings are the same (hence why every ring and pinion needs to be set up in that particular axle, it comes down to thousandths of a inch but in gears that can matter), swap the carrier from one with the ring gear, shims and bearings to the other as well as the pinion. but don't just call it quits there, and throw the cover on it. I'd get some marking paint and check the pattern to make sure it is acceptable, if that housing is different by 5 to 10 thousandths of inch the gears won't be set-up ideally.
                ...And by then you would have already put too much thought into a D35.
                  Will said asshat
                    Originally posted by Henchman View Post
                    Will said asshat
                    i love it when he does that
                      none of us wheel here. We just drive to the mall and back. Then beat our jeeps in with hammers so it looks like we wheeled it. Seriously dude you're not starting out on a good foot here.
                        www.jeepforum.com
                        HAVE FUN!
                          Will said asshat
                            all these treads about dana35's
                              How did I miss this one!?!?
                              Damn, so many one liners down the drain! I wont be able to live with myself after this oversight...
