So just picked up a d44 for my cj out of a commando. So needless to say, its a bit rusty. Just seeing what some of your techniques were. I have some por15 leftover that i'll probably use. But other then wire brush and sanding what are some ways you attack it?
Rust Removal
ive had good luck with flap disc's, takes everything off and leaves the axle in good shape to paint.
8.8 with brackets cut off, cleaned, painted to primer
dana30 housing cleaned, painted charcoal Grey metallic
x4 I used a dewalt 4.5in knotted wire brush on my 11,000rpm shitty 4.5in harbor freight angle grinder to remove the rust from my frame rails and surface rust from my good condition floor pans. I am going to use this same set-up for my new 44 as well, because it worked almost too well. Just good advice pick up some heavy duty hearth, or welding gloves. Mine are 2 layers of HEAVY leather, a layer of fire retardant, a layer of cotton, a layer of some fabric mesh, a layer of cotton again, a layer of some more random fabric, then some soft liner on the inside and I can stop the brush with my hand and still not make it down to flesh. Those brushes are very nasty though. So wear protection at all times. And Coating can really be done with anything as long as you fully clean any dust off and preferably use some metal prep. IMHO a sandblaster just takes much longer and should only be used for small parts with light rust and in tight areas. Unless you have a huge sandblaster the size of a house.Originally posted by jeepbogger4x4 View Postx3. i used a wire wheel on my axle and floor pans and it only took about a day. probably one of the easiest and quickest waysLast edited by WickedXJ; 11-01-2010, 07:14 PM.Jeeps don't get stuck ... they just take a nap when they are tired of being awesome
Eric
