My brothers girlfriend has some sort of issue with her fathers pontoon boat, and something on the pontoon itself needs to be welded.
Is there any sort of advice you can give me? I would imagine the main worry would be burn-through, so similar to sheet metal just take your time and do small sections with very low heat?
I was also under the impression you should be using straight Argon, is it fine if I just use the same bottle of CO2/Ar mix that I have right now?
I'm going to try and scrounge up some scrap pieces I have lying around and give it a whirl.
