I have Created Barpin Replacinators.
  • I have Created Barpin Replacinators.
    Seeing as how Barpins are devilish objects, with their sole purpose to bring pain and disdain to those who wish to install Shock Absorbers in their vehicles, I set out to create myself and other some Bar Pin Replacinators. Since the Term Eliminator is already taken by other people and their fancy Bullshit, I simply came up with my own.
    They are made from 5/8" Stainless Steel rod, machined down to spec and high polished to reduce corrosion.
    nice.... only problem is the rear upper mount bolts still suck ass
      I'm going to install them on an empty stomach so I can eat all the dirt that falls onto my face.
        Bang up job chap.
        Never had an issue with the upper bolts
        1 break them
        2 punch broken stud out
        3 drop bolt in
        4 tack in place
        5 win
          not to mention the rear upper bolts only suck the first time you remove them
          ive probably done and undone them about 50 times since stock
          buttery
            buttery
            I was quite amazed how well yours came out this morning - Didn't even need a wrench.
              Guess you guys are right after the issue has been addressed once its not a big deal... And phil I wasnt meaning anything negative towards them wish i had the skilzz
                All it takes is a lathe and a Mill...and I got two of each.
                  Very nice once again philip. Sort of want to make but mine are already set for now. Maybe we should start a business making chit like dis
                    Thanks dude. I say you make your own anyway.
                      Am I missing something obvious?
                      They look like just as much of a pain in the ass as barpins. If you were going to spend this much time making something, you would have been better off throwing a sleeve in the bushing of your shock and running a normal bolt through. Make a different mount than that garbage stock sheet metal(talking about the rear mounts).
                      I don't mean to be "that asshole", I just thought I would throw my opinion out there.
                        Except those are once piece stainless, not the sheet that they stamp and roll for the stock ones that are hollow and bend and all that fun, i made a set of these at school real quick for my xj and they held up really good. weren't nearly as pretty though.
                        BTW they look good Phil
                          Clearly you are missing something insanly Obvious, so let me point it out for you.
                          These barpins DO NOT have flares ends. Though they are 5/8" in diameter, I can push these in by hand. I don't have to grind the edges down, or hammer then in, or even use a vice. Just a little oil and these can be pushed right it, no sleeves or anything else necessary. They are for a stock mounting location for the rear, and I'm not cutting my jeep apart and building a shock hoop and just 'putting a bolt through it' because that to me is more work then spending an hour to make these bar pins. I have the resources and the knowledge to make these rather then chop up my jeep and make unnecessary modifications.
                            i like it, probably 100x stronger then the thin sheetmetal pins you get in shocks
                              they look like what old man emu sells with thier shocks
