Finally making those long arms...
  • #61
    Originally posted by WAD357 View Post
    Why not buy brand new currie Johnny Joints? theyre cheap like 40 bucks each...
    im running a jhonny joint on the axle, rubber bushing on the xmember, and either a rubber or keep the s.f joint on the upper to lower connection
    • #62
      I thought the SF joints were shot?
      • #63
        gonna tear into em later this week, my buddy said they look bad, another said to tighten em and grease em
        • #64
          Odds are the sf joints are shot. I would personally run the brushing on the axle to tale up any mis- alignment and vibration so the joints won't
          • #65
            i was gonna do that, but if i have the rubber on the xmember, it will smoothen the on road ride which is my main goal
            • #66
              What x member are you using?
              • #67
                home made
                • #68
                  Can you post a pic of it?
                  • #69
                    I've never seen an aftermarket kit run this way, only with the rubber/poly on the axle end.
                    I don't know for sure if it will make a difference, but it's something to think about.
                    • #70
                      Same. I get the feeling it will death wabble like a mo-fo
                      • #71
                        dont waste your time with SF joints, especially ones you need to tighten. if youre makin arms, start fresh. preferably with something better than SF joints, like the already mentioned currie joints.
                        • #72
                          I figured since that joint will be the only component contacting the frame, it would be better to have less movement.
                          • #73
                            i wouldnt put a rubber bushing on the crossmember...
                            all the forces from the uppers and lowers are transfered to that point in a radius arm. the bushing would prolly where out in a month. also the joints at the crossmeber end see the most movement. therefore you would want a spherical joint at that point.
                            take a look at trail gears creeper joints... i used them on my last build and they are beefy, cheep, and havent had any issues...
                            so run a poly or rubber on the lower axle... joint on crossmember, joint on upper arm.
                            • #74
                              CREEPER JOINT
                              check them out, but if ya go with them be sure to use a few washers or a spacer on them to get the misalignment you need out of them.
                              i had to scrap a crossmeber becuase i made the tabs 2 5/8" apart and the joint could barely move
                              • #75
                                This is along the lines of what I was thinking as well.
