Originally posted by WAD357
Finally making those long arms...
Originally posted by LittleD View Posti was gonna do that, but if i have the rubber on the xmember, it will smoothen the on road ride which is my main goal
I don't know for sure if it will make a difference, but it's something to think about.
Originally posted by Even View PostI've never seen an aftermarket kit run this way, only with the rubber/poly on the axle end.
I don't know for sure if it will make a difference, but it's something to think about.I don't always drink orange juice, but when I do, I prefer to chew it. #madpulp
dont waste your time with SF joints, especially ones you need to tighten. if youre makin arms, start fresh. preferably with something better than SF joints, like the already mentioned currie joints.- Will
i wouldnt put a rubber bushing on the crossmember...
all the forces from the uppers and lowers are transfered to that point in a radius arm. the bushing would prolly where out in a month. also the joints at the crossmeber end see the most movement. therefore you would want a spherical joint at that point.
take a look at trail gears creeper joints... i used them on my last build and they are beefy, cheep, and havent had any issues...
so run a poly or rubber on the lower axle... joint on crossmember, joint on upper arm.Originally posted by Ktmracer419some people choose video games
CREEPER JOINT
check them out, but if ya go with them be sure to use a few washers or a spacer on them to get the misalignment you need out of them.
i had to scrap a crossmeber becuase i made the tabs 2 5/8" apart and the joint could barely moveOriginally posted by Ktmracer419some people choose video games
