So I've been busy even though it doesn't look like much each little part takes time.
But this is what I got so far.
The axles are coming along machining the Super Duty unit bearings to 5 on 5.5, and the rotors to fit.
Just looking up all the different parts needed take a lot of time.
I spent a little bit of time looking up a Jana 54 axle Dana 50 gears in a Dana 44.
I have the stock D50 gears so I was going to install them into the Dana 44 housing with a welded carrier, 30 spline and run the stock D50 shaft for now.
Later Upgrade to 35 spline ARB makes 35 spline locker I also talked to Motive Gear they said they should have a 35 spline Spool on the market next year. I hope they keep their promise.
Yukon said they have no intentions going after the 35 spline D44 market.
I'm going to be order Axle tubing soon. I should be able to get everything tacked I don't want to set my caster until the end.
Buggies are a lot of work but will be so worth it when I'm finished.
I also just got an engine stand so next is to start working on the Ecotec.
Balance shaft delete replumbing the breather to the middle of the engine so it will not spill oil on a roll over. (just an idea I had).
