So I've started, the ultra light buggy design. I'm not expecting it to be finished for a couple years
I haven't gotten very far. Things keep changing but I have most of the hard parts ironed out. I figure I'd post what I got so far.
My intentions are to run RCrocs Crawling Class 4, RCrocs Racing, KOH, WE-Rock Pro Modified, Southwick Racing Unlimited Class, and best of all Street Legal.
I'm trying to keep the design simple and with common/part availability number 1 so I can get the cookie cutter operation going. I know a lot of the ideas are just pipe dreams I expect a lot of sacrifices are going to be made to make it all work together.
I’ve been doing a lot of researching and this is my recipe so far.
Motor:
Ecotec naturally aspirated for now.
Spark MSD distributor, ignition box, coil, and wires. 4 Paddle Reluctor Wheel, MSD P/N: PRD15377
Fuel: Propane or the Holley Commander 950 fuel injection off my CJ.
Alternator I’m hoping Powermaster can wire me up a single wire one.
Transmission:
AX15 internal slave
Sky Bell housing (GM PN 89060089)
Clutch 84 4cly camaro (1-1/8" 10spline 9" dia)
Pressure Plate
Jeep Hydraulic Slave
Pilot bearing from a 91 XJ
Transfercase: too many options I want to leave room for all.
231
247 all wheel drive with clutch pack nice for the road low range lockout.
300
231/300
Atlas out of my price range for now.
Suspension:
A lot of up travel I want the links and axle to clear the engine.
I want the to design full bump the rims level with the skid plate.
Front:
3 link ORI struts
Rear:
3 link ORI struts
Rear Axle
HP D60
TJ 35 spline shafts
5.38 gears
Spool or air locker if I have the money might go open for now save some money
Torino Set20 flange
Front Axle
HP D44 (Jana 54) D50 gears (I'll see if I can get it to work)
5.38 Air Locker open for now save some money
I decided to go with the axle U-joint strength of the Dana 60.
Still going to use a HP44 but the outers are going to be D50/60 knuckles and Cs.
Use the Unit bearing version from 3/22/99 to 2004 F250,F350,F450
The Hub need to be machined to 5 on 5.5 bolt pattern and inner spindles opened up for 35plines when upgraded.
D50 uses 30 spline similar toe D44 and D60 uses 35 spline which is available upgrade with ARB.
I will still fabricate my own Knuckles so I can setup my own steering arms.
This should actually be easier than D30 the ball joint presses into the knuckle so it is just a round bore D30 is tapered.
Only issues is finding seals for a front D44 with 35 splines.
I figure this route will save me about 200lbs over a Kingpin D60
RCV axle shafts I like the CV shafts over U-joints smoother action but I’ll run stock shafts for now.
Brakes:
Master: Willwood triple set
CNC cutting brakes
Front:
(fabricated knuckle) Dodge 1500 2001 down rotors.
Calipers, 79 Chevy G1500 (GM standard 1/2 ton)
Rear:
Dodge 1500 2001 down rotors. with centering spacer.
(Cutlass/Cadillac with E-brake calipers to meet E-brake rules.) If Needed
Steering:
Full Hydro,
Ram on back side of axle
Ackermann set up for max turning of each tire not the best for high speed but this can be adjusted with fabricated knuckles
Pump PSC makes brackets for the Ecotec.
Radiator:
Location ?
Chassis:
2 Seater
Mild Steel design after everything is in the optimum location.
Wheel Base around 104, I'm shooting for 100 it is easier to make it longer than shorter.
Seats:
Corbeau, Baja XP
Body:
Polyethylene sheets fabricated to make a body.
Fenders will bolt onto axle/knuckle (street legal)
Windshield: CJ bolted on to pass inspection has correct stamping and windshield wipers sunglass or Lexan windshield from there out.
Tires:
37 meet WE-Rock Promod.
Inner Air Bead locks
Winch front/rear
Sway bar TBD
I’m sure I’ve missed a lot but I’ll keep updating it as I go.
Here is a little preview
Motor:
Transmission:
AX15 internal slave
Pressure Plate
231
300
231/300
Suspension:
Front:
3 link ORI struts
Rear:
3 link ORI struts
Rear Axle
HP D60
TJ 35 spline shafts
5.38 gears
Torino Set20 flange
Front Axle
Code:
66” width (XJ 60” hits my links) Unit Bearing outers C’s will be gusseted, Knuckle will be Fabricated. Unit bearings are lighter and allow more room for a larger CV joint. Hubs the bearings are further apart stronger bearings heavier smaller CV joint
Brakes:
CNC cutting brakes
Front:
Rear:
Steering:
Full Hydro,
Radiator:
Location ?
Chassis:
2 Seater
Seats:
Corbeau, Baja XP
Body:
Tires:
Winch front/rear
Sway bar TBD
