i kno i am going back a long time but the pictures on the first page, what long arm setup is that? and how many inches of lift? im thinking of doing this so im just doing a little bit of digging. thanks!
Grundle Jeep
Originally posted by CntStpTheStnk06 View Posti kno i am going back a long time but the pictures on the first page, what long arm setup is that? and how many inches of lift? im thinking of doing this so im just doing a little bit of digging. thanks!
b4 i took it to RC I installed RE4.5" springs and took out the spacers and body lift.... much betterthe way the Clayton kit is designed you need to run 4" of suspension lift at a minimum. my friend has the 5.5" Clayton and it preforms excellent
Originally posted by HeavyMetal View Postclub compin this thing?
Even if the jeep is 100% by then I haven't wheeled in over a year, so i wanna get some local seat time in the thing first.
On a side note, I should have just replaced the entire frame. All the BS i had to do to support everything and the work it took to get stuff to line up properly I regret it.
a basic 'whats left' list:
- finish weld the frame
- plate the frame
- weld in new control arm brackets
- make new rear control arms (have all the parts)
- weld in rear spring retainers
- new rear shock x-member
- new brake lines (rotted out)
- longer drive shaft
- trim tub
finally got the frame finished welded, pain in the ass doing the drivers side inside and the bottom.
some assembly required
wheelbase looks like its going to be in the ~99" range. tried to salvage my clayton frame brackets but it wasnt worth the struggle. So im going to order some up monday.Last edited by grundlepunch; 04-03-2011, 09:11 AM."when I'm riding my motorcycle,I'm glad to be alive...when I stop riding my motorcycle,I'm glad to be alive"
