The HeavyMetal Project
  • They're installed. Nice kit.
    • 2000 XJ: "The Black Jeep"
      • Originally posted by Customjob View Post
        Id say youre good for a while but id be careful because PVC becomes britle when it gets old. Not sure how long this takes. Neat idea though and it looks cool
        out in the sun it gets brittle in a few years, not to the point that it would break in this application though, but fails epically when there is 130psi water sitting in it
        1992 xj Briarwood
        Welded front and rear
        13' LED roof lights
        Disco ball
        Truck nuts
        Spinners
          where can i obtain these
          -jake........sorry for any of my spelling fails i was droped on my head when i was little.
          Quote Phill: Do you drink lots of coffee? I drink it once in a while and I get varying effects. Some days it doesn't bother me but others my heart races like a greyhound from the Vet after the owners realize that it cant race anymore and needs to die. Fuck that, find me some owner with big tits and I'll be cute and slow the rest of my life.
          • Awesome idea for the axle shafts,maybe you can stuff some sort of foam blocks in the ends to keep them from banging into the ends.
            • Originally posted by 96jeepman View Post
              http://cgi.ebay.com/ebaymotors/1997-...Q5fAccessories
              theyre those, i didnt get the corner lights with em though
                shake you sir
                • Any update on the maxximus traxion kreapycrawlars?
                  2013 F150 fx4 (Tow Pig/DD)
                  • 5.0 with the 3.73 option
                  2003 TJ Rubicon
                  • 4.0/42rle/np241or
                  • 5.13's
                  • 33” BFG KO2s
                  • Originally posted by SupermanIce-J View Post
                    due to the national shortage, i probably wont have a set until late fall
                    it was either they gave me a set of bighorns now, or i just waited it out for the creepy crawler stock
                    waitin it out!
                    theres still enough life in the STTs to use them this season without worry
                    • Good call, I watched Dave shred a BigHorn sidewall on a dirt hill.
                      • cage additions thoughts
                        for my final step of stiffening (after i straighten the front end unibody) i would like to complete the jeeps cage to the front
                        red bars are the existing a-pillar bars, transparent where they are behind the body/fender
                        yellow would be additional
                        cage 1:
                        typical engine cage, in jeepspeeds and similar. run a bar behind/in front of/through the firewall, NOT on top of the jeep visible (possible? havent looked at all closely, either way, a thought) and then forward across the bay, out of the front clip and into the bumper push bar. engine bars are mounted via bolt on flanges, to be removable.
                        cage 2: again, havent looked closely for clearance on this, just thoughts while i work. same bar off of the a-pillars to span the jeep, and then bars running down the inner fenders, mounting to the inside of the bumper face somewhere, flange mounted again.
                        cage 2 is less invasive and doesnt scream I HAVE A CAGE COMING OUT OF MY FRONT CLIP!!! ..id like to do it but need to assess the room for working it
                        • You know how to use Miscrosoft paint?
                          • actually.............no
                            • i like option 1, any way to add a vertical bar down to the frame half way through? kinda hard to describe, and i dont feel like playing with paint right now
                              bar across the engine would be cool too
                              • i like the idea of bars going down the inside of the fenders if possible. that way when you crawl and lean into a tree it will save the fender as well as strengthen the front end
