what are you doing about that wheel
Project: Rebuilt
just at a curiosity why did you weld the brackets in a upside down u rather then a normal u....
her is my representation...lT instead of l_l... it seems lik under droop the shock will come into contact
Maybe i just have a small mind. cant wait to see it perform.2013 F150 fx4 (Tow Pig/DD)- 5.0 with the 3.73 option
- 5.13's
- 33” BFG KO2s
Originally posted by Supermanxj View Postjust at a curiosity why did you weld the brackets in a upside down u rather then a normal u....
Maybe i just have a small mind. cant wait to see it perform.sigpic
Went on a little cruise today and the jeep seems to soak up bumps even better now. Not sure how that works but I was legit trying to hit bumps and it seemed better. I found a nice flat parking lot and both sides measure out at an even 5 inches of shock shaft showing. Im guessing the spool likes to throw it off because it torques the rear end up when i turn. I really wanted about 4.5" of shaft showing but when I figure with the weight of me and a passenger, I should be right around there. I still want to get some new coils or at least test some others out and see if its worth it. Further testing will hopefully be done today after I get caught up on school work because I decided to do shock mounts instead
Also, I was looking under it today and found my pitman arm nut on the box was loose to the point where the lock washer wasnt doing anything.whoops
Originally posted by Lawn Guyland View Postits supposed to be pretty insane here...but then again LI is just waiting to be washed away89XJ Pioneer Edition 3.5" 33s ravines 4:10s 8.8- parted but not forgotten
95XJ tons 3 link 36s 5:38s
97 F-250HD 7.3 Turbo Diesel
"Shut up and Wheel"
Test drive # 2. Everything seemed great. it flexed well and the shocks didnt seem to come into contact with the mounts. I only flexed to the point where it was just barely touching the bump and I still had an inch and a half of shock travel and about an inch and a half until the tire hit the fender. I didnt get much high speed test in but i did get to do a little bit on a potholey road. It did well. no bottoming out or anything. The only thing I really need to do is rebuild the UCA joints BAD. and the leaf bushings are bad already too. Fucking Rustys.
