Project: Rebuilt
Jeepspeed v. 2.0 has begun. FINALLY got around to doing my lower shock mounts so my Foxs dont keep gettin killed.
A tech thread if you will.
First started by Cutting off the old mounting perch.
I used Ruff Stuff Shock mounts that I had from my 8.8 swap kit and welded them up in place where I wanted them.
This is the passenger side but I did the same thing on the driver side. I used some 1/8 plate I had laying around and gave it some gussetting. This ties into not only the shock mount itself, but also the LCA mount so it strengthens the whole thing.
I used some shock bushing sleeves I had laying around to act as spacers in between the heims and the shock mount. Got some grade 8 hardware and tightened it all up. All painted and ready to go
and bam, done. The pics suck but you get the point.
Your welds are becoming medium-medium wellP8R
I'm a fan of the shock mount's. I think I might try that.
What about the stock mount's was killing your shocks though?01 XJ 3" on 33's and some new paint n stuff. Gone.
Originally posted by iant333 View PostI'm a fan of the shock mount's. I think I might try that.
What about the stock mount's was killing your shocks though?2000 XJ: "The Black Jeep"MK2 Jetta > M3Chairman of the Chechnyan Space Program
What about the stock mount's was killing your shocks though?P8R
Originally posted by SwampAss View Postget some.
At full flex, with the angle the mounts are at, are you worried about the shock getting bound up on the edge? If you can see what I'm trying to get across?
oh and i FINALLY got somewhere with Rough Country and the UCA joints. They didnt send me new joints but they did send me rebuild kits. So I will be doing those on friday. I also noticed that my axle is tilted way to far forward so thats why my coils look sad. So when i put the joints back in, I will adjust that
