mine has 4" lift packs in the front, because of the boom shackle in the rear with how low the shackle mount is it t evens it out with the front, i have stock hangers and placement in the front. Any time i could come over and see it?
Heres my project YJ
well its at my work, i work on it most nights. So just let me know when you can swing down after 5pm and i will let you look it over.85 K10, 44front,ff14 rear, 350,th350,Np208, 39.5/13.5r20 IROKs. almost done
New toy 88 yj, 4.2, 5speed,231. Its getting a soa, 78 f350 dana 60s, SYE, and some 37s.
So have you been slacking on the updates or working on the Jeep????
- 99TJ 4.0 4.5 RE springs, Clayton 5in LA stretch, GenRight Armor, 35x12.50 bfg mt, currie hp9 rear w/ 35 spline detroit, hp44 w/ arb and 4340 axles, k/n fipk, banks headers, warn xd9000i
Been sick and havent wanted to work on the HEEP lately. Staying late tonight to work on her a little bit. need to get some parts ordered before i can get to much more done.85 K10, 44front,ff14 rear, 350,th350,Np208, 39.5/13.5r20 IROKs. almost done
OK been slacking lately on the jeep but need to get it goin again. So i ordered all my steering parts today from parts mike and sent out my pitman arm to them to have it reamed. hopefully get it all back by next week and get it in. Goin to order my rear corners this week as well so there will be some updates too.85 K10, 44front,ff14 rear, 350,th350,Np208, 39.5/13.5r20 IROKs. almost done
WELL HERE IS A TON OF PICS AND UPDATES
I havent had time to get around to updating this in awhile since I started a new job had to move the jeep home from my old shop but i got some good pics on here and got a lot done in the last few months with all the other stuff goin on.
So first i called up Parts Mike and got him to send me a HD steering set up for a Dana 60 High steer arms and his HD T-style steering.
I also i fixed my front spring hangers and lowered them a little. you can see them in the above pics.
Next I had my girl buy me some tube fenders they are from the web site jeeptubes, they just send you the tubes and you have to make the mounts and skin it with some sheetmetal. then coated them with some bedliner.
Next i called up SniperFab works and talked to the guys there and custom ordered a set of their rear corners to fit my streach, a set of rocker guards and some rear flares that the custom bent so i could make them fit the corner guards. spent a few days cutting, welding and drilling and got them installed.
So thats where she sitts right nowLast edited by ctchevy; 08-22-2009, 01:50 PM.85 K10, 44front,ff14 rear, 350,th350,Np208, 39.5/13.5r20 IROKs. almost done
that is quite sweet dude, i like the fenders
Thanks for the kind words guys, i cant wait to get it done. but money is tight right now so its goin to take a little longer then i thought.
Next up is the SYE, then the wiring and brake lines, cage, shocks and driveshafts. not to much more to go85 K10, 44front,ff14 rear, 350,th350,Np208, 39.5/13.5r20 IROKs. almost done
Looks great, glad to see an update here, keep up the good work1950 Willys Trail Rig
The H2s with the GM center caps are really stylin too.1950 Willys Trail Rig
Yeah i just had that one kicking around my old shop so i just wanted to see how it would work, with the right lug nuts i mite run them not sure yet though. for the fronts i will just cut a big hole for the HUB.85 K10, 44front,ff14 rear, 350,th350,Np208, 39.5/13.5r20 IROKs. almost done
Back from the dead.....hopefully this BUMP will get you motivated buddy!!!
