Bell Off Road/ Jonasson Motorsports YJ Build
  • #31
    Few teasers:
    YJ on 37s, coilovers, etc
    MaxRev MotorMedia
    • #32
      Pro comps eh?
      • #33
        I already miss the mt/rs that were used for mockup. Love the stance of the jeep though
        • #34
          Went up Metal Masher today:
          MaxRev MotorMedia
          • #35
            Moab shots:
            MaxRev MotorMedia
            • #36
              Came out awesome dude
              • #37
                we went up moab rim after you left
                • #38
                  I went up saturday evening while you were out at BFE. Only thing I didn't get to do was Pritchett Canyon. But I might be back in Moab in May so...
                  MaxRev MotorMedia
                  • #39
                    Thanks, when are you guys coming for a visit out west?
                    MaxRev MotorMedia
                    • #40
                      ill be in norcal in 2 days...are you going to be washingtoning?
                      • #41
                        Yea I'll be up here for a while, should have come with me for a week instead of staying in Utah.
                        MaxRev MotorMedia
                        • #42
                          Finally got around to doing a little math and figuring out my corner weights so I can dial the spring rates in. Right now I am sitting at:
                          725 lbs D front
                          675 lbs P front
                          506 lbs D rear
                          487 lbs P rear
                          Full Droop:
                          Sitting with about 4 inches of uptravel left:
                          MaxRev MotorMedia
                          • #43
                            This finally showed up:
                            MaxRev MotorMedia
                            • #44
                              Since the box is pushed so far forward the tube was notched a bit to clear the top of the box, the bar fits in fine and clears with no issues.
                              The AntiRock links had to be bent out to clear the coilovers and panhard mount:
                              He got started on the Redneck Ram mount for the axle side the other day, decided to use the diff cover to mount it:
                              Then my new brakelines from Clayton Off Road showed up, with a couple of their nifty bottle openers and some swag:
                              MaxRev MotorMedia
                              • #45
                                AntiRock mounts done:
                                I picked up the Clayton lines for the front, but the rear line wasn't going to work. So we dig some digging at the parts store and ended up with the combo below. The high end of the hard line will have a short (8" or so) double ended female line connected to the hard line on the frame:
                                WestTexas Offroad Redneck Ram mounted and plumbed:
                                MaxRev MotorMedia
