Project 'Damn I wish it didn't have a chrome grill'
    Originally posted by tjramplebump View Post
    what kinda paint did you use? that came out REALLYwell
    Originally posted by loudobbs View Post
    Tell me about it. I was just looking to hide the rust but after the first coat I was astonished. Its just flat black rustoleum from the automotive paint section at home depot.
    You should paint that hanus chrome grill with the same stuff! Just kiddin man great lookin jeep. Looks like you know how to have fun with it. I have 4.10s and 33s on my wrangler. Drives like a sports car and gets close to 20 mpg
    1950 Willys Trail Rig
      I was thinking about it, but I am still deciding what to do with the paint, if anything. I like the white/black combo... but I also like all black...
      2001 TJ
      2001 Tahoe
      2013 M3
      1986 R65
      1997 Blackbird
      2013 R1200GS
        Aussie for the 8.8 showed up... this thing is BEEFY. Ordering another for the front on friday, and putting them in in a couple weeks. Expect to see a mabell wheeling run thread
        2001 TJ
        2001 Tahoe
        2013 M3
        1986 R65
        1997 Blackbird
        2013 R1200GS
          FYI - I'm told that with the removal of a few screws that chrome grill will come right out - Its just an insert.
          - 99TJ 4.0 4.5 RE springs, Clayton 5in LA stretch, GenRight Armor, 35x12.50 bfg mt, currie hp9 rear w/ 35 spline detroit, hp44 w/ arb and 4340 axles, k/n fipk, banks headers, warn xd9000i
            d30 aussie ordered!
            2001 TJ
            2001 Tahoe
            2013 M3
            1986 R65
            1997 Blackbird
            2013 R1200GS
                nice. wheel the shit out of it
                  Got the aussie for the d30... when I picked it up I damn near threw it, expecting it to be as beefy as the one for the 8.8. Its like half the size. Putting them in next friday in my buddies garage.
                  2001 TJ
                  2001 Tahoe
                  2013 M3
                  1986 R65
                  1997 Blackbird
                  2013 R1200GS
                    Got the aussies in. The 8.8 was easy, though a bit tricky figuring out a good way to get the c-clip in. Once we had everything together my buddy relaized he forgot the thrust washer for the passenger side... which I asked several times if he remembered. So we got to do that job twice. The front was a bitch in 2 spots; I forgot the yj's have 3 axle shafts and remember about a half hour into trying to get the front carrier out. Pulled the middle shaft and it came right out. But then the little pin that holds the center pin in place was a bitch and a half to get out. I was using an allen key to hammer it out, but it wouldnt budge. We went to autozone and got some punches. The only one that fit broke in about 3 hits with a hammer. But, for kicks I tried the allen key again, and luckily it finally started moving. Wrestling the 3 bolts holding the axle on was quite the bitch as well. But its all done now, fully locked;
                    my buddy mike, still smiling as its the first time we took apart the 8.8
                    8.8 built
                    d30 opened up
                    building the aussie in front
                    done, and WOW what a difference. This rock is nothing all the impressive but it was around the corner and enough to test with;
                    Took it to mabell the next day and officially ate the jeepeater. With these things its like wheeling with god mode enabled. Crawled up just about everything, and a few spots required a tiny bit of throttle.
                    The chick driving up a pretty decent rock face;
                    So, now that thats done... my tcase is shot. It was popping quite a bit wheeling and rattling the whole ride home. So I guess a new drive line is up next.
                    2001 TJ
                    2001 Tahoe
                    2013 M3
                    1986 R65
                    1997 Blackbird
                    2013 R1200GS
                      nice man! i have an Aussie in the rear of mine and man what a world of difference just the rear makes, i cant imagine the front locked too, Great job!
                        Yeah its an amazing difference. Wheeling with open diffs got to be really frustrating, I had to just take the plunge.
                        2001 TJ
                        2001 Tahoe
                        2013 M3
                        1986 R65
                        1997 Blackbird
                        2013 R1200GS
                          when you take the carrier out with the ring gear on it, can you just bolt the carrier back in or do you have to check the measurments and stuff. like spacing?
                            You're supposed to check the measurements for backlash and whatever, but I could give a shit about that stuff since this is no DD, so I just slapped it all back in and bolted it up.
                            2001 TJ
                            2001 Tahoe
                            2013 M3
                            1986 R65
                            1997 Blackbird
                            2013 R1200GS
                              ahh hah. but would that even change because your not changing shims right?
                                theoretically, but I may still be off from stock as I have no clue how old my shims are.
                                2001 TJ
                                2001 Tahoe
                                2013 M3
                                1986 R65
                                1997 Blackbird
                                2013 R1200GS
