AngryTj's Rubicon Build
  • AngryTJ
    replied
    Originally posted by konastinky1234 View Post
    hey had a question for ya, not sure if i missed it or not...
    1. Why short fronts and mid rear arms? I know you stretched so obviously longer rears came with that but are you shooting to make longer fronts? Or sticking with the hi clearance, short arm approach? Just curious.
    2. What kind of shock towers are those ones you used there for the rear shocks? It looks like you ran them outside of the frame which is cool and I want to outboard soon.
    3. Mabel on Sunday?
    Sorry I completely missed this.
    Short arms in the front work for now until I'm brave enough to build a 3 link with bridge over the diff.
    The towers are actually Dave's customs unlimited. Cheapest towers around other then using a ford shock tower.
    Let me know next time your going to Mabel and ill come for sure
    Leave a comment:
  • konastinky1234
    replied
    Originally posted by Henchman View Post
    They look like gen right towers
    sounds expensive. back to fabricating my own i guess
    Leave a comment:
  • Henchman
    replied
    Leave a comment:
  • konastinky1234
    replied
    3. Mabel on Sunday?
    Leave a comment:
  • AngryTJ
    replied
    Got a few little things done last night:
    Installed the hood pins and front signal lights
    Rewired my CB to the battery and installed the PSC fender vents
    Also was able to mess with the mounting point of my CB antenna, remount my windshield frame armor, and retighten all the jam nuts on my CAs.
    Leave a comment:
  • AngryTJ
    replied
    pic in the daylight
    Inner fenders
    First pics from the new Canon Rebel t3i! Excuse the lack of hood pins and few other items in these pics
    Leave a comment:
  • AngryTJ
    replied
    Originally posted by kfeal View Post
    This thing is awesome. Great work dude.
    Thanks man!
    Had a late night last night but was able to finish everything I needed to in order to drop the jeep off at my cousins before leaving for vacation today. While I'm away he's going to try and fix my small oil leak, do an oil change, and if he has time install my synergy ball joints and swap in my front superior axle shafts.
    The jeep drove home great, very smooth no vibes or anything so thus far Im very happy.
    Parts came out AAmazing and I freakin love these PSC fenders.
    Took a few pics.
    Havent seen this site in over 4 months
    I did have a slight issue initially with the gas tank not registering how much gas I had and instead showing completely empty with the light on but by the time I got home it kicked back to normal and the gas gauge works again.
    Granted the pics arent the greatest but thats all I have right now. Off to Punta Cana!
    Leave a comment:
  • kfeal
    replied
    Leave a comment:
  • AngryTJ
    replied
    measured and cut shock tower
    welded in
    Remounted the genright tank
    She has a rake since I went with stiffer springs in the rear and the back is empty. But shes finally off jackstands!!
    Painted the cage
    Installed harness'
    Ill eventually need to attach some velco straps to my seat covers to keep the harness' over my shoulders
    Mounted Evap
    Tightened all my control arms
    Switched the front springs to have them on the correct side
    Mounted front bump stops
    Painted and installed windshield armor
    Painted Chromo front shafts
    Put the windshield back
    adjusted the front trackbar
    Took her for a short test drive!
    Still to do:
    Install front Superior Shafts
    Extend Sliders
    Install Rear LEDs
    Mount winch
    Re-install rear antirock
    Replace various bolts. Couple transmission and engine skid bolts were missing
    Got my new hood on last night and tonight Ill be installing the fenders and corner armor
    Leave a comment:
  • AngryTJ
    replied
    Originally posted by Grandzjtsi View Post
    Nice work! This thing is getting some serious $$$ and time thrown at it!
    Thanks man! I actually traded my full doors to a guy for a highline hood and him painting all my parts.
    Glad to see someone actually looks at this thread I figured noone did since its not a XJ
    Leave a comment:
  • Grandzjtsi
    replied
    Leave a comment:
  • AngryTJ
    replied
    custom highline hood, fenders and corner armor has been painted
    Leave a comment:
  • AngryTJ
    replied
    Thats his rig he's using to mount my fenders and make the hood on and in the meantime I got the rear frame welded up, coil buckets are set and the control arms are done. Couple slight issues however...first off I made the upper arms too long so Ill have to cut them and either use a slug to attach the arm together again or try cutting off the bung on one end and then shorter then arm and reweld the bung.
    Second issue is with shocks. The first pic shows how the shocks currently mount which only allows them to be mounted completely vertical. The problem with that is my genright tank mounts directly in the location the shock would need to be. The plan is to cut the end off my lower shock mount, drill a cross hole through and mount them in the opposite direction so I can freely angle the body of the shock further back on the frame. Hope that makes sense.
    Frame welded up
    I did get to do some of my first welds which came out pretty well. The majority of the welding my buddy did while I was occupied with other stuff.
    Final money shot. Springs arent in and the tire is just mocked in place not actually mounted.
    Leave a comment:
  • AngryTJ
    replied
    Im having a guy on jeepforum make me a custom high line hood and paint my new fenders and corner armor..shots of the new fenders and custom hood:
    Stretched steel corners with larger wheel well and welded flares
    Love these fenders
    Leave a comment:
  • AngryTJ
    replied
    Spent a few hours after work tonight cutting and prepping for welding. Finished the driveside
    Notched the rear crossmember enough to fit the stock coil bucket
    notched the coil bucket as well
    Finished cutting and did a lot of grinding so this side is ready to weld up.
    Leave a comment:
