Goal: an all around trail truck, built for heavy abuse. Ultra 4 in spirit, deff not in motor though, cause i'm a poor bastard. But, I am building it light, sleek, lots of uptravel and a super low stance. The plans with this are to run the RCrocs Race series in 2012.
Started life as an 88 yj, now its cut, alot.
Specs
Drivetrain:
Ford Racing 302 with Painless Wiring Fuel Injection
Ford C6 transmission
Atlas 3.8, 2 speed, 1350 yokes, 32 spline outputs
Tom Woods Driveshafts
Axles:
Front- narrowed 65" wms HP Dana 60, Chevy outers, Superior 5.38 gears, Detroit locker, 35 spline chromolly everything from superior axle, CTM u-joints, 5x5.5 bolt pattern, Solid 35 spline drive flanges, fabricated double sheer high steer arms
Rear- 65" wms Solid Axle Semi-float LP Dana 60, superior 5.38 gears, ARB air locker, superior 35 spline axle shafts, 5x5.5 bolt pattern
Suspension:
14" travel Bilstein 9100 2.0" Body Coilovers with Remote Reservoirs and anti-cavitation valving
Double Triangulated 4 link rear
Triangulated 4 link front -- links utilize Currie Johnny Joints and yuppp square tube
Fox 2.0 Air Bumpstops
Designed around a 112" wheelbase with 8" of uptravel
Bypasses when i can afford them
Wheels and Tires:
39" Red Label BF Goodrich Krawlers
17" Walker Evans Aluminum Beadlocks 5x5.5 bolt pattern
Chassis:
designed and built by me, utilizes the middle section of the yj frame, from right in front of the motor mounts to where the rear 4-link starts.
1.75" .120 wall DOM
Narrowed Jeep TJ Grill
Misc:
PSC Double Ended Steering Ram and Orbital
CJR Power Steering Pump from RoushYates
Summit Racing 18 Gallon Fuel Cell
Ron Davis Radiator with dual Electric Fans
PRP Seats
Coolers for P.S. and transmission from B&M
Cooler for cold drinks between the two seats
Wilwood Dual Master Cylinder brakes from Speedway Motors
CNC cutting brakes
And that's how she starts, pictures and updates to come as work progresses and its not raining.
Before I go any further I need to take a second to acknowledge the people and companies that without their help, this build and this truck, would not be possible.
- Adam and Clayton from Clayton Offroad
- Justin Williams from Custom Creations, LLC
- Phil Larocca of Gunsmithing Ltd, for tons of help in machining various parts, and some hubs already, thank you!!! will post bling pics of bling 60 hubs, when we finish them.
- Solid Axle
- Poly Performance
- Currie Enterprises
- Steve Usher, for getting me a smoking deal on tires
- Coors Light and my buddy Josh, who helped me total my XJ, therefore driving this project forward.
and last but not least, Mr. William Gentile of HMC, for his feverish support and uncanny motivation, (i'm actually doing it fucker
Specs
Drivetrain:
Axles:
Suspension:
Wheels and Tires:
Chassis:
1.75" .120 wall DOM
Misc:
PRP Seats
CNC cutting brakes
- Solid Axle
- Poly Performance
