banging. too bad you gotta modify it right out of the box.
My WJ Build
That looks fucking mean!Originally posted by Pedro View PostSome of the install and paint. Had to cut a pretty significant piece of the front sheet metal away to get the bumper to line up right. Also has to remove the washer fluid bottle as well. Apparently zj ones work in wjs and are out of the way, so I'm going to look into that. Otherwise it wasn't that bad of an install.
Got a couple things since the bumper. I just picked up a mopar hitch and hitch bezel from a guy on JU for some rear recovery and to tow the 4 wheeler if I ever need too. Got some new Clayton 4.5" coils to make up the weight of the front bumper.... And get rid of the RC ones. Speaking of getting rid of RC stuff I got some JKS quick discos to replace the pain in the ass RC ones too.
Still contemplating Clayton front long arms......hint Zatt Mullo hint.......P8R
Nope, the 99-01 has the charcoal canister in the way of where the zj bottle will go whereas the later ones don'tOriginally posted by Robin Fairchild View PostLooks awesome.
Did you end up finding a bottle or do you need one? I found my spare.
Edit: IDK if your WJ has a washer fluid level sensor, but the ZJ bottle I have doesn't have a hole for it.
there really isn't much you can do except get a universal bottle from NAPA and drill out the right size holes for the sensors and motors. Then mount it wherever.
Got to work on it for a few hours today, with minimal help from Andrew!
anyway I got the old IRO short arms and RC coils out as well as the old crossmember. I got the new Clayton crossmember in and bolted up as well as the new coils and prothanes for bumpstops. Not quite sure on the right length I'll need for them, but figured I can cut them later. On Thursday I will hopefully get the arms in and welded sometime soon after that. I also put the new JKS discos in as well
hitch came too
