it all sucks
My WJ Build
I know, I'm just trying to fit inOriginally posted by Lawn Guyland View Postit all sucks
They are coil inserts made by Prothane. They are essentially a tube of polyurethane that you put in the coil and cut down to the right size you need. Essentially a soft progressive bumpstop rather than the hard stock one. You can order them from Jegs. The upper black tube part are IRO coil retainers.Originally posted by _R700_ View PostHi, sweet WJ! Can you please give me some info on the bump stops? Never seen this setup on a WJ before. Where did you get it and how does it mount? Thanks.P8R
Thanks for the info! Gonna check it out nowOriginally posted by Pedro View PostThey are coil inserts made by Prothane. They are essentially a tube of polyurethane that you put in the coil and cut down to the right size you need. Essentially a soft progressive bumpstop rather than the hard stock one. You can order them from Jegs. The upper black tube part are IRO coil retainers.
As far as I know it fits any 44a, didn't really ask tho. Only place I found them is Facebook. Search around on JF and you'll find it too.Originally posted by Robin Fairchild View PostI like that 44a skid. Is it WJ specific?
Sent from my pay phone in ChechnyaP8R
got the washer bottle done today. Being a 2000 I had the charcoal canister in the way so i ouldnt use a zj bottle, but since I have a k&n intake I prayed I had enough room for the new bottle. Its just a universal napa overflow bottle. I mounted the pump on the bottom of the bottle since it fit in the spot the best that way and used a lot of RTV as well to seal it all up. Kindof crude, but works mint. lets hope it lasts! It held around half a gallon I'd say.
The intake, wire, and a zip tie are holding it in place now. Going to try to think of something better, maybe a metal band and some self tappers into the fender well.
You can see the pump underneath here.
The dubs seen more wheeling time this year than your xj.......that you just sold...........to dizzy........
