Hmmmm if I don't buy you food will that be ok too
My WJ Build
Originally posted by Burton58 View PostHmmmm if I don't buy you food will that be ok tooP8R
This is the game we're playing now.... I seeP8R
Originally posted by DizzDizz View PostIs it in yet??P8R
It's still sitting on my porch, I'm waiting on some hardware. I may start taking the stock bumper off today tho.Last edited by Pedro; 01-26-2014, 09:07 AM.P8R
Turns out I really didn't need hardware and it uses existing bolts that are already there. Durf. Now I feel like an idiot. Anyway I wouldn't of known until I tore into it anyway. S I decided to work on my jeep without Andrew and got to here, except I need to cut some metal and didn't have a cutoff wheel. So I'll hopefully painted and get it mounted up soon. Also got a JCR light mount for the fairlead to mount my Hellas.
Originally posted by DizzDizz View PostYou should clear coat the bumper just like that.P8R
Some of the install and paint. Had to cut a pretty significant piece of the front sheet metal away to get the bumper to line up right. Also has to remove the washer fluid bottle as well. Apparently zj ones work in wjs and are out of the way, so I'm going to look into that. Otherwise it wasn't that bad of an install.
Here is really the only problem we had. When I went to drive it the rub was ridiculous. Apparently they designed this on a stock wj. Looks like I'm going to have to cut a lot of the metal away.
All done
