So I got this comanche off Hux, I've always wanted one and this one looked pretty solid minus the bed rust and some floor boards. I kinda just want a capable pickup truck I can ue for utility purposes..my 2wd just doesnt cut it for most things. My plans are a SOA rear with an 8.25 (which I also got from Hux haha) a D30 front of course with 4.5 inch springs and upper and lower control arms, 33 inch tires..etc. Then depending on what I do for my cherokee it will either end up with my current axles with 4.56 gears or a D30/44 combo with 4.88's Idk yet. I'll also use her as a guiney pic for figuring front pillar measurments for a cage and whatnot. Then some rust repair and paint....And maybe wayy down the road a full 97+ drivetrain and dash swap..but I'd need to find the perfect donor cherokee for that. I only have 1 pic so far but I'll keep it updated as I go.
So far I've determined that all of the cylinders run about 140psi even for compression which aint bad for 193xxx miles, and after having the valve cover off theres no sign of sludge and after clearing out the valve cover vacuum line she doesnt appear to have any blowby..So knock on wood I hope she has some good miles left in her.
