5.7 Hemi engine.
  • 5.7 Hemi engine.
    Thats right, its really a Hemi. This is an engine that was pulled out of a 2006 Charger R/T. Im still contemplating whether or not I want to keep this thing since I just put a couple bucks into it to rebuild it. A little history on this engine. It was pulled out of an 06 Charger for a lower end knock and was replaced with a junkyard motor. I pulled it apart and found a bent connecting rod was the cause of the knock. The reason it was knocking was because the guy had driven through a puddle and got a water in the intake. Each piston/rod assembly was checked and all were still perfect and straight. no blown head gaskets, engine was not overheated, cylinder heads are still mint, no bent valves, no bent pushrods, etc etc. It was ran for a total of 5 miles after the knock started, pulled out and put on the side. I took out the old bent piston assy and replaced it with a mopar one. Head gaskets are all new Fel-Pro. Everything torqued to spec. The engine had religious Mobil 1 oil changes as well every 4-5k. Very well taken care of and the internals were clean as a whistle when I pulled it apart. The engine only has about 62k miles on it. The engine has everything on it except thermostat housing, headers (I have them, with the O2 sensors, but the studs are bent and need to be replaced as well as new gaskets), the intake man needs to be replaced because it was the one off the junkyard motor and was broken when it was delivered. Does not come with accessories like PS pump, alternator, and AC compressor because I dont have them. they didnt come with the other motor so they had to be switched over. As of now I cant think of anything it does or doesnt have. PM me if interested. As I said I may want to keep it for a project of my own but if the money is right I may take it. It seems the going rate for these things is between 2500 and 3k and the JY motor that replaced it was 2850. So shoot me some offers and Ill let you know. I have the VIN from the vehicle, the engine cover, and the engine harness.
    You guys change the main, rod, and cam bearings?
      new rod bearings in the new piston/rod assembly yes. cam bearings and main bearings were not touched.
        Dont sell it.
        Hemi + GoKart =
        Shenanigans motor
          Originally posted by ninetysix-ex-jay View Post
          Dont sell it.
          Hemi + GoKart =
          Shenanigans motor
          HEMI + XJ + LII =
            This is one of those things to put under a blue tarp and keep it in the back of the garage until the opportunity presents itself...
              X22
                I am just saying... if you got it for free then you should feel ashamed to sell it for that kind of money... Donating to a cause would make you a great person.
                2013 F150 fx4 (Tow Pig/DD)
                • 5.0 with the 3.73 option
                2003 TJ Rubicon
                • 4.0/42rle/np241or
                • 5.13's
                • 33” BFG KO2s
                  Dude, serious put it in Petes Jeep
                    I'll trade you the 4.7L in our wk
                    Shane "The Bag" Carlson
                    My "Bucket" Build
                    MilitaryJeepers.com
                    ‚——P--;===±--= <-
                    !‚–’¯ƒ¹¶
                        If I end up keeping it I will slowly purchase the parts I need so when I can afford to throw it in, I will(giggity)
                          Seriously, keep it.
                            you pretty much owe pete, you know, cause you rolled his jeep
